Introduction: Easy Paper Flower
This instruction is to make a beautiful flower out of paper.
The supplies you will need are....
- Ruler
- Glue
- Scissors
- Dark green paper
- Any coloured paper you would like to use for the flower e.g. purple, red and blue.
Step 1: The Flower
Take the colour you would like to use to make your flower petals and cut it into a rectangle approximately 30cm long and 5 cm wide. Now make a a little fold against the edge. Carefully press this down.
Step 2: The Petals
Now cut all along the rectangle but do not cut into the fold. Do not make the cuts too big or too small try to make them about 0.5 cm to 1 cm wide.
Step 3: Folding
Now that you have made the cuts start to roll the cuts to curl them. Roll it up till it reaches the fold.
Step 4: Stem
Start making your stem. Take your dark green paper and cut it into a long strip about as wide as the last one but a half longer.
Step 5: Glue and Rolling
Now start by putting glue along one edge of the stem and fold it in to look like a cylinder.
Step 6: Put It All Together
Wrap the flower around the stem by first putting glue on one half of the stem and then using the piece you folded to wrap the flower around the stem.
Step 7: Done
Now you have a paper flower
