Introduction: Paper Mache Mushroom
this is a paper mache mushroom for easy crafty décor.
paper
glue
paint
hot glue
exacto knife or scissors
Step 1:
grab thin paper and measure/mark it for every inch
Step 2:
cut as much paper as you feel necessary at the inch mark. you can repeat this step later on if more paper is required.
Step 3:
grab a balloon and inflate it
Step 4:
secure the balloon down to something so it doesn't move around
Step 5:
cover the top half of the balloon in a nice layer of glue that looks like the shape of a bowl
Step 6:
use the paper you cut out earlier and paste it using the glue on the balloon. make this into the shape of a bowl
Step 7:
you want to do at least 2-3 layers of this to make sure the paper holds. once it is fully formed in the shape of the bowl paint on one last layer of glue and let it dry.
Step 8:
after the paper is fully dry pop the balloon and peel it off of the paper.
Step 9:
grab pieces of full paper and roll them up to create a large roll.
Step 10:
take a piece of paper and put glue on one edge. then place the rolled up paper on the glue.
Step 11:
roll the paper roll into the new paper to make the roll thicker
Step 12:
once you get the roll to about an inch or more of thickness get your cut pieces of paper and apply glue on one side of them.
Step 13:
place the piece of paper around the rolled paper to add thickness of the paper around the bottom.
Step 14:
hot glue the stem of the mushroom that you just made to the center of the inside of the paper bowl.
Step 15:
cut out lots paper in this shape to put on the inside of the bowl.
Step 16:
glue the pieces of paper into the bowl like this.
Step 17:
once all the pieces are glued in dry paint on some brown in order to add dimension.
Step 18:
paint the stem.
Step 19:
mix paint to paint the mushroom cap.
Step 20:
paint the cap of the mushroom.
Step 21:
once the paint is fully on and dried paint on white dots. this can be done with 3D paint or normal white paint according to preference.
Step 22:
once the paint is dried you are done!!
