Introduction: Paper Maché Death Star
Walking down the sidewalk I once came across this transparent plastic sphere. I scooped it up into my arms and took it home hoping to use it for some fun project. And that day came when I was asked to make a death star (from star wars) for a little friend.
Materials
- a plastic sphere (a "wine bladder")
- plastic wrap for food
- Newspaper
- Flour and water glue
- PVA glue
- paint white, black, blue and yellow
- brushes
- masking tape
+skewer and fluorescent paint
Step 1: Wrap the Thing Up
1.- The first thing I did was cover the sphere with plastic wrap, so that I could later remove the papier-mâché and only use it as a mold.
Then I made the glue by mixing flour and water in a metal pot and put it to heat on the stove until it thickens.
I used this mix to paste together pieces of newspaper in layer, several layers... using a brush.
I let the sphere dry for several days and repeated the process again.
Step 2: Cut It, Join the Parts
2. Once dry and very hard, cut the sphere lengthwise with a knife and make some marks where I should join the parts later. I was very careful with the "neck" of the sphere.
you can use masking tape or scotch tape
Once the plastic sphere mold is used, I can save it for other projects like an astronaut helmet.
Step 3: And Wrap It Again
3. I joined both parts with tape taking into account the marks I made so that the parts coincide. Then I covered everything again with more newspaper and the flour and water paste.
I also mark a better circle for the window and bent a wire as a hanger
I let dry
Step 4: Cover the Window
4. For the "window" I use of the hollow space on the plastic sphere.
I cut out a circle and strips of thin cardboard. I stapled them together, and glued them into "the window hole".
I covered everything with newspaper and glue.
Step 5: Paint and Make the Stripes
5. Once is ultra dry, I painted the paper sphere with a mix of black and white paint to achieve a light gray. Then I cut very thin pieces of masking tape and put them on the paper sphere to make the "death star" separation
- I made the vertical lines first and then the horizontal ones, then i divided the spaces using more masking tape.
Step 6: And Paint Again
6. To paint the windows I mixed white + black and blue paint on a flat surface and painted the sphere covered with masking tape with all the mixture at the same time . By painting with all the shades at once, depth is achieved.
- For the window, I added a bit of yellow paint to the mix to give it more light. I also put some yellow strokes for shineness in random parts of the sphere. And painted the black lines with a fine brush
- then I added PVA glue mixed with water to make it shine.
Step 7: Little Shiny Lights
i bought a bottle of fluorescent paint and painted little dots (I used a skewer) like little lights. It took me like an hour to paint all the dots... anyway.
that's it.
