Introduction: Paper Plane Launcher Gun
Hi All,
I received a suggestion from "coolcrafter101" that I should make the paper plane launcher as a gun.
In this intructable, I will share how to make paper plane launcher gun or version 2 to my paper plane launcher i shared last month.
Hope you like it !!
https://youtu.be/FvAhiuDFau8
Step 1: What Do We Need ?
• 0.75" x 3/16" Wooden strip ( max 2 ft )
• On / Off Switch
• 2 Wheels
• AA batteries
• 3V DC motors
• Battery holder
• Fevicol / PVA glue
• Double side tape
• Wires
Tools
• Hex Saw
• Dremel
• Paper tape
• Acrylic Paint and brush
• Soldering iron
Step 2: Wooden Frame Assembly
To build the frame, we need to cut the wooden strips into
- Main - 5.5" - 1 no
- Guides - 5" - 2 nos
- Handle - 3.25" - 1 no
- Motor holder - 0.75" - 1 no ( depends on the wheel radius , we need very small gap between them , smaller than 1/32")
I used hex saw for straight cuts and angles / joints used dremel
Caution: Dremel may jump around if you try to cut faster. Wait and gently perform the cut
Assembly
- Fix the Motor holder on the main wooden strip using joint
- Fix the 2 guides with 0.25" dept as shown
- Use paper tape to hold the guides while the pva glue / fevicol dries
- Make grove for switch, add extra wooden strips to hold the switch in place
- Leave it to dry for 4 to 5 hours
I donot have clamps so using paper tapes to hold the wood strips close
Paint Job
Use acrylic paint it with shades of your choice. Look into internet for inspiration
Donot use too much of water, let t dry for 1 hr
Step 3: Electrical Connections
Electrical connections are simple, first test the motors and find the direction. We need motors to move in clock and in anti clock directions.
Using double side tapes fix the motors and battery holder as shown
Connect wires to the motor and battery holder with a switch
Gap between the two wheels should be approx 1/32", which ca be adjusted by adding 1mm foam to the wheels
Step 4: Play With It
Once All done, make few paper planes and play with your kid
Please share your comments
