Introduction: Paper Pulp Sheets
Hi everyone,
This is the first process experimenting with paper pulp. At the end of the process i got some paper pulp sheets.
Using this sheets i made a mini park bench model.
OK let's start
Old newspapers
Mixer grinder
Fevicol + water
Warm water
Wooden sticks 4 nos (1 cm thickness)
Cutting knife
Glue
Step 1: Preparation
Take old newspapers and tear it into small pieces.
Soak all the papers in warm water over night.
Step 2: Grinding the Papers
After soaking into water, drain the water and put it into the mixie jar
and grind it smoothly. Add small amount of water in between grinding.
Now you get a paste like pulp.
Step 3: Adding Fevicol
Now add little bit of water in fevicol.
Pour the fevicol + water mixture into the pulp and mix it well
Step 4: Making the Wooden Frame
Now take the wooden sticks and joint them using glue.
Spread the paper pulp inside the wooden frame.
Dry this until the water content removed.
Step 5: Final Product
After drying you can get sheet of paper pulp.
Cut the edges and make it small pieces.
cut it into 5 in x 2 in
5 in x 1.5 in
1.5 in x 1 in (2 nos)
Now attach all pieces using glue.
You can get a mini size park bench.
Thanks a lot.....
please vote for me.
