Introduction: Paper Quilled Doll
This paper quilled doll has been made with different designs of quilled pieces and then joined together.
Step 1: What You Need?
- Different colors of 5 mm wide quilling papers
- Quilling needle
- Glue
- Scissors
Step 2: Creating Base
- First we will create the base with white quilling paper
- Make a tight coil with 10 strips, joining one with the other with glue
- Flatten the coil
- Make a cone out of the coil
- Apply glue inside the cone and dry
Step 3: First Layer of Cones on the Base
- Join two violet colored strips together and make tight coil
- Make a cone from the coil and apply glue inside
- We need about 8 pieces of these.
- Glue these cones around the base as shown in the picture
Step 4: 2nd, 3rd, and 4th Layers With Quilled Cones
- Using 1-1/2 strips of rose colored paper, create 8 pieces of cones as earlier
- Glue these cones around the violet ones already fixed to the base. This will make the second layer
- With one strip of yellow paper make 8 pieces of cones
- Glue these pieces in between rose colored cones and make the third layer
- Lastly, make 8 cones with pink paper each with 3/4th length of paper strips
- Glue these cones around one half of the base as fourth layer. This will be the backside of the doll.
Step 5: Making Waist and Body
- Make a dome shape as shown for waist. This can be done with 8 strips of Blue paper
- Glue the waist portion above the already constructed base
- Make some tiny cones - 1/2 strip
- Add another layer with the cones
- Make a dome of 8 strips for the body
Step 6: Making Upper Body
- Make upper body with cream and blue
- Paste the upper body
Step 7: How to Make Hair?
- Paste paper strips as follows
- Paste the hair dome to face dome
- Make outer layer of hair
- Paste the outer layer to the head
Step 8: Pasting Head to the Body
- Paste the head , neck and body
- Curl the hair
- Curl the front hair too
Step 9: Making Hands
- Make 2 small cones for each hand
- Paste the hands
Step 10: Making Fringed Flowers
- Make fringe with 5mm blue paper
- Make small fringed flowers
- Add the fringed flowers to neck line
Step 11: Adding Glitter
- Add sparkles to give a glow
Our paper quilled doll is ready
