Introduction: Paper Quilled Earrings | Plants Vs Zombies
Sometimes earrings are all you need to spice up your appearance!
Plants vs Zombies has always been my favorite game since I was a kid. I thought it's going to be great if I made one of the plant characters. So I decided to make Chomper (plants character) earrings using paper. Even if you don't know the inspiration, it's still fun to look at!
In this project I used:
- Colored paper: Violet, green, and pink
- Scissors
- Tweezers
- Cutting pen
- Quilling mold
- PVA glue/white glue
- Wire
- Earring hooks
Step 1: The Head
Cut the violet paper into 0.2 cm width, then make a tight coil by rolling the tip of the paper strip. Don't forget to give some space (hole) in the first roll for the earrings hook (see the first picture). The coils I made were 2 cm in diameter. Mold the coil to make a bowl, and secure the shape by applying the glue. Wait until dry (while waiting you can prepare the tongue in step 2).
After that join the two bowls to make the head of Chomper. I added a little paper strip on the back to add extra security.
Step 2: The Tongue
I used a 1 cm paper strip to make the tongue by rolling the corner of the strip until I get a cone shape. Secure the cone by adding a little glue. Then, glue the cone inside the head
Step 3:
Chomper has green lips. To add that detail, cut green paper into a 0.2 cm strip and then glue it down on the head.
Step 4: The Thorn and Tooth
To add the thorn on the head, I used the cone technique from step number two but using a 0.5 cm green paper strip. I made 4 thorns and attach them to the head.
To make the tooth, draw an arch and cut in zigzag outside the arch line. The result will look like eyelashes extension. Then glue it inside the mouth.
Step 5: The Leaves
There are upper leaves (behind the head) and bottom leaves. The upper leaves are smaller than the bottom leaves.
Make a tight coil using a 0.2 cm green paper strip. Pinch the coil to make a leave-shaped coil. Then glue the leaves side by side. For the upper leaves, I used 5 coils, and for the bottom, I used 3 coils.
Step 6: The Stem
Cut the violet paper into 2 cm x 3cm pieces. Place a wire on the paper, then roll the paper. Secure the paper by adding glue. Now we can bend the stem as we want. Place the tip of the stem in the center of the upper leaves, and also the bottom leaves, apply some glue, and wait until they are completely dry.
After that attach the head to the upper leaves by adding some glue.
Now we have Chomper
Advance: You can cover this paper quilling using varnish to add more protection
Step 7: The Hook
Insert the wire into the hole on the head. Bend the tip of the wire to secure it. Add earring hooks and the Chomper earrings are ready to rock!
Thank you for reading this instructable to the end. If you have any question, please don't hesitate to write in the comment or contact me through my instagram @quinzyvarira. I will also upload some footages of the process in my instagram account.
I would love it if you wanted to support my projects, please consider helping me to cover the cost of designing, documenting and sharing these projects on https://ko-fi.com/quinzyvarira.
See you in the next instructable! 😁
