Introduction: Paper Quilling Flower
Simple easy to make flower made of paper strips
Step 1: Supplies
You will need,
1. Different shades of red and green paper strips
2. Glue
3. Quilling needle
Step 2: The Base
Start with rolling two strips of green paper into a circle of about 1/2 an inch in diameter. The circle should be tightly bound. Then push the centre out gently to create a dome shape as shown in the picture.
Step 3: The Petals
Now make the petals by rolling two pink strips into a circle. Let the circle unroll a little and then then stick the end. Pinch the opposite ends of the circle to give it a petal shape. you will need four of these petals
Step 4: Inside Petals
Make similar petals but this time in red paper strips and smaller than the pink ones.
Step 5: Stick the Flower Together
Stick one end of each petal in the concave side of the green dome. The bigger pink petals first...
Step 6: All the Petals
...the smaller red petals will go on top of the pink ones as shown in the picture.
Step 7: The Centre
Make another dome like the green one you had made earlier but this time with a dark red strip of paper and stick it at the centre of the flower over the red petals and its done.
