Introduction: Paper Rings Chain Sukkah Decorations Under 5 Minutes! - DIY
Is it Sukkot already and your sukkah is looking kind of.. sad?
Or maybe you want to celebrate an event at home and need some pop of color to get the party started?
I'm here for you!
Together we will make a beautiful paper rings decorations you can hang wherever you want the good vibes will be!
- Colored papers (or white ones, as we'll use in this tutorial) - any size will do
- Scissors
- Stapler
- Marker pens/crayons
- Duct tape (for a final touch)
Step 1: Cut Paper Stripes
Using the scissors, cut stripes out of the papers either horizontally or vertically (depends on the desired paper ring size)
Step 2: (OPTIONAL) Color the Stripes
You can now use the marker pens/crayons to write or color the stripes - so that everyone will see your beautiful drawings on the hanged decoration on the end!
Step 3: Make RINGS
Using the stapler, close the first ring.
After that, insert a new stripe inside the first rings, and then close that ring with the stapler while the first one is inside of it (as shown in the pictures).
Repeat this step until you have reached the desired chain length!
Step 4: (OPTIONAL) Final Touch - Hang the Decoration
While it's possible you want to leave the chain as a center piece in the middle pf the table (understandable), some of you may want to hang it on the wall between lamps.
To do so - use the duct tape and attach a piece of duct tape to each side of the chain, and use it to attach it to the desired place.
Step 5: Invite People to Get Jealous of Your New Decor
Honestly, do i need to elaborate?
ENJOY!!!
