Introduction: Paper Star
This is a hacken cool star i could make a million of!!!
Step 1: First Step
First start with a strip of paper. Tie a “knot” in the end of your paper.
Step 2:
Pull gently to tighten, then flatten. Fold the end of the strip down and tuck it into the knot.
You can cut a bit of it off if it's too long.
Step 3:
Keep wrapping until you get to the end of the strip.
Tuck the last bit of the strip into the pouch. You should be left with a cute little pentagon.
Step 4:
Now to make this little pentagon into a star, very gently and slowly use your fingernail to press on the center of each of its edges. The star should puff out.
Step 5:
And you should have a lovely little lucky star!
It may take some practise to get the star to puff out perfectly, but stick with it... you’ll get it!
If you are having a lot of trouble, try different papers, or try wrapping the strip of paper around without creasing it too much. This helps a bit!
