Introduction: Paper Towel Holder
I created a paper towel holder that has an external arm extended from the front in order to make tearing more accessible and easy.
I would recommend using either metal or wood for the body of the paper towel holder, either nails or screws to attach into a wall, and either a hammer or a screwdriver to fasten the paper towel holder into the wall.
Step 1: Sketch
Using Onshape, create a sketch that makes a circle with a diameter of 0.5 inches to create the roller for the paper towel roll.
Step 2: Extrude
Extrude the circle to the right one inch.
Step 3: Extrude
On the opposite side, extrude the circle to the left one inch.
Step 4: Sketch
Create a sketch on the side of the left side of the cylinder and create a square on the center point of the left side of the cylinder with both a width and length of 0.25 inches.
Step 5: Extrude
Extrude the square to the left 0.5 inches.
Step 6: Sketch
Create a sketch on the side of the right side of the cylinder and create a square on the center point of the right side of the cylinder with both a width and length of 0.25 inches.
Step 7: Extrude
Extrude the square to the right 0.5 inches.
Step 8: Sketch
Create a sketch on the back of the right rectangle.
Step 9: Sketch
On the sketch create a square on the right side of the back side of the rectangle with both a width and length of 0.25 inches.
Step 10: Extrude
Extrude the square backwards 0.5 inches.
Step 11: Sketch
Create a sketch on the back of the left rectangle.
Step 12: Sketch
On the sketch create a square on the left side of the back side of the rectangle with both a width and length of 0.25 inches.
Step 13: Extrude
Step 14: Sketch
Create a sketch on the front of the left rectangle.
Step 15: Sketch
On the sketch create a square on the left side of the front side of the rectangle with both a width and length of 0.25 inches.
Step 16: Extrude
Extrude the square forward 1 inch.
Step 17: Sketch
Create a sketch on the left side of the rectangle.
Step 18: Sketch
On the sketch create a square on the right side of the front side of the rectangle with both a width and length of 0.25 inches.
Step 19: Extrude
Extrude the square to the right 2.25 inches.
Step 20: Sketch
Create a sketch on the back side of the right rectangle.
Step 21: Sketch
On the sketch create a circle on the back side of the rectangle with a circumference of 0.5 inches.
Step 22: Extrude
Extrude the circle backwards 0.5 inches.
Step 23: Sketch
Create a sketch on the back side of the left rectangle.
Step 24: Sketch
Step 25: Extrude
