Introduction: Paperclip Cube
This instructable will demonstrate how to make a cube from paperclips!
Supplies:
- paper clips
- scissors
- Welder
- welding wire
- masking tape
Step 1: Set Up
First, turn on the welding machine so it has time to heat up. Straighten out the paper clips and cut 12 equal sized pieces.
Step 2: Assemble
Next, arrange the paper clip pieces in a square and secure it with masking tape. Weld the 4 corners together using the welding machine and the welding wire. To weld, make sure to heat up the paperclip pieces for a while and then put the welding wire next to the 2 paperclip pieces to weld them together. Repeat again to get 2 squares welded together.
Step 3: Assemble and End
After welding the 2 squares, tape them to the floor using masking tape to ensure they don't move and weld them together to eventually form a cube. If possible, have someone hold the square or papercut piece up when welding or use a clamp to hold it in place while welding. Finally, finish welding and make sure to let your cube cool down from welding!
