Introduction: Papercraft Zombies
About: Inventor of the Fizzbit.
Quick and easy to make Papercraft Zombie decorations.
They can also creep around with the addition of a Fizzbit.
Step 1: Step 1: What You Need
You need:
The template printed onto white card (if you have any, otherwise office paper will do)
Scissors
Glue (UHU type is a bit quicker but PVA works too)
If you want your zombies to move you also need
3 Fizzbits
3 self-adhesive pads (or pieces of double sided sticky tape)
Step 2: Step 2: Cut Out the First Zombie
Cut along the solid lines around the first Zombie and its arms.
Step 3: Step 3: Fold and Glue the Body
Fold along the dotted lines, put glue on the tabs and then stick the body together.
Step 4: Step 4: Fold and Attach the Arms
Fold along the dotted lines on the arms and glue them onto the side of the body in a suitably creepy position. If you don't want your zombie to move you are done! Just make the other two in the same way and find a good spot for them to decorate your halloween party. To make them move read on...
Step 5: Step 5: Add the Fizzbit
Pop your Zombie down on its head and stick a sticky pad just inside the hole at the back. Attach the Fizzbit to this pad. If you are using double-sided tape stick a bit to the flat part of the Fizzbit (under the motor) and stick this inside the Zombie's head.
Step 6: Step 6: Make the Other Zombies
Repeat these steps for the other two zombies and you are done!
If they have Fizzbits you can plug your zombies into some USB ports for 30s and then send them off on a terrifying rampage.
If you want to go big there are templates here to make double-size zombies (1 A4 page each).
There is also a blank template so you can design and colour in your own zombies.
Have a creepy time! ;)
