Introduction: Papperlapapp... a Raspberry Pi Based Music Player
PAPPERLAPAPP is a rude German term to interrupt somebody and tell him he is talking nonsense.
Pappe is the German term for cardboard.
During a discussion in a FB group about "the right wood for steampunk" this word comes in my mind. ;-)
And like a song I have had this word in mind the whole day: "Papperlapapp" this brought me to "Pappe" >> cardboard. After a while I found some cardboard tubes and the story began.
Material:
- RaspBerry Pi Zero (W)
- micro SD - card
- USB - HUB for Zero
- WLAN Stick (if no zero w)
- HiFi Berry Amp
- 2 mini speaker 4Ohm
- Some bits and pieces
- cardboard tubes or something similar
- a spare USB cord
- an old meter 6 - 10 V
- wax stain
Step 1: Building the Case
The case was build from 3 cardboard tubes.
For the front end and caps I used pressed cardboard.
The tubes where glued together like the picture above.
After this the holes for meter and speakers where drilled.
Step 2: Painting
Painting cardboard is not such easy. I used water based stain and painted it in 4 layers. I used the oven at 60 degrees Celsius to dry it between the layers. (Don´t tell my wife) ;-)
After this I used painted 4 layers of wax stain and after everything was dried 3 layers of shellac.
Step 3: Mounting Everythin Together
I used an USB extension to bring one USB - port outside and hold the RasPi.
Step 4: The Software and the Meter
I decided to use Volumi-
Volumio comes with a lot of plugins and is my favorite player.
To monitor that the player was correctly shut down I connect the meter to the Tx pin of the RasPi. These pin will be high during normal operation and becomes low if the shutdown process is finished.
