Introduction: Paracord Bracelet Without Buckle (Tutorial)
Step 1: Supplies You Will Need
You will need 2 colors of paracord. One longe for the weave and one for the base of the bracelet.
Step 2:
Have the desired color cut to the length you want then start the weave..if u don't know the weave I suggest you to check out my first paracord bracelet tutorial..but if you know it, then awesome :D
Step 3:
Once you start the weave leave some of the excess string (the base) out a little bit longer like in the picture shown.
Once you start the weave continue the weave till u feel its long enough
Step 4:
So this is how long I want my bracelet to be.
But when u get to your desired length make sure there is excess string (the base) at the bottom like on the top.
Step 5:
Cut the excess string off and sings the ends.
Step 6:
Then tie the base strings you left at the begging and at the end, you need to tie a knot with the strings. One string tie a knot on one string and do the same with the other string. Like so in the pictures.
Step 7:
Once that's don't..cut the excess strings off and singe the ends. Like so in the pic
Step 8:
Now you have a bracelet without a buckle. They are also adjustable so they can fit bigger wrist as well
Thanks for checking this out. Hope you enjoyed it
