Introduction: Paracord Keychain
Make a Paracord Keychain, the Paracord supplies to get, 3 ft of Paracord, a Key ring, some scissors and a lighter. If you want to make a 2 color Paracord Keychain, melt the 2 pieces of paracord together. Attach the Paracord to the key ring, like in the picture below. Make the loop as long as you want the Paracord keychain to be, minus a 1 inch loop at the end. Already made this try these otherParacord Projects.
Step 1: Paracord Keychain, 1
This is the Cobra weave Paracord keychain. Lay the first piece of Paracord across the two pieces of paracord horizontally. This will be the center color, and the side color on the revise side of the paracord keychain. Now bring the second piece of paracord over the top of the first piece of paracord, around the back, and up through the hole made by the first piece of paracord. Then pull it tight.
Step 2: Paracord Keychain, 2
Continue the Paracord Weave, lay the first piece of paracord across, bring the second piece of paracord over the top, around the back of the paracord keychain, and up through the hole, and pull it tight. Already made this get Paracord Bracelet Instructions.
Step 3: Paracord Keychain, 3
Your almost done, keep braiding. Bring the first piece of paracord across, bring the second piece of paracord over the top, round the back, and up through the hole. Stop when your about a inch from the end, or how ever long you want the loop. You can use this braid to make a Paracord Bracelet too.
Step 4: Paracord Keychain, 4
Once you have the paracord keychain as long as you want. If you have a Paracord needle, run the ends back into the braid. Other wise just cut and melt the ends. Note, cut off the ends as close to the Paracord as possible. You can also make it with a carabiner or clip on the end. You can also make a DNA Paracord Keychain, just alternate the piece of paracord that you lay horizontally across. Now learn How to make a Paracord Bracelet, or try these other Paracord Projects.
