Introduction: Parametric Illuminated Sign / Rotulo Luminoso Parametrico
Hello everyone, a few weeks ago a friend had a convention and he wanted his pc to stand out among all the others, that's where this idea came from, a easy created illuminated sign. After that, I have improved it with different options so that it is easily customizable and anyone can make their own.
Hola a todos, hace unas semanas un amigo tenia una convención y quería que su pc destacase entre todos los demás, de ahí surgió esta idea, un rotulo luminoso fácil. Tras aquel, lo he mejorado con diferentes opciones para que sea fácilmente personalizable y cualquiera pueda realizar el suyo propio.
We will need:
- A piece of methacrylate.
- An RGB led strip with or without a driver, here we will see the two examples.
- A 3d printer for the base, although it can be changed to a cnc since it could be carved in wood if desired.
- A CNC or a CO2 laser (the latter is more recommended) to be able to engrave the methacrylate.
Necesitaremos:
- Un trozo de metraquilato.
- Una tira led RGB con o sin driver, aqui veremos los dos ejemplos.
- Una impresora 3d para la base, aunque puede cambiarse por una cnc ya que podria tallarse en madera si se quisiera.
- Una CNC o un laser de CO2 (mas recomendado este ultimo) para poder grabar el metraquilato.
Step 1: The Base / La Base
The base is made in fusion 360, you only have to open the file and in parameters, modify the width of the methacrylate and the thickness of the one you are going to use. The height is reflected as the amount that the methacrylate penetrates into the base, it is 2cm by default, which prevents light from reflecting where it shouldn't and hold the sign. The base in turn has the given tolerances, so you simply write the methacrylate values, then download the two pieces and print. If you are going to use leds without a driver, I have designed a piece that I leave here to supplement its hole.
La base esta realizada en fusion 360, solo tendrán que abrir el archivo y en parámetros, modificar el ancho del metraquilato y el grosor del que vaya a usar. La altura esta reflejada como la cantidad que penetra el metraquilato en la base, esta por defecto en 2cm, los cuales evitan que la luz refleje por donde no debe y sujetan el cartel. La base a su vez tiene las tolerancias dadas, asi que usted de simplemente escriba los valores del metraquilato, luego descargue las dos piezas y a imprimir. Si van a utilizar leds sin driver, he diseñado una pieza que aquí les dejo para poder suplementar el hueco del mismo.
Step 2: Design of Sign / Diseño Del Letrero
To make these designs, you must take some considerations,
- The designs must be made in mirror mode, so that the engraved part is hidden.
- When centering the drawing, remember that the methacrylate has a depth of 2 cm, which will be hidden in the base.
- If you do it with cnc, the thicker the methacrylate is, the easier it will be since it will spread the heat better and prevent it from melting. And do it in the direction of travel, although it will also depend on the cutters you are using. I have used these:
- V bit 30º (to record)
- 2mm one lip (face cut)
Para realizar estos diseños, deberá de tomar algunas consideraciones,
- Los diseños han de hacerse en modo espejo, para que la parte grabada quede oculta.
- A la hora de centrar el dibujo, recuerde que el metraquilato tiene una profundidad de 2 cm, que quedaran ocultos en la base.
- Si lo realiza con cnc, mientras mas grosor tenga el metraquilato, mas sencillo será ya que propagara mejor el calor y evitara q se funda. Y hacerlo en el sentido de la marcha, aunque también dependerá de las fresas que este usando. Yo he usado estas:
- V bit 30º (para grabar)
- 2mm un labio (cara cortar)
Step 3: Assembly With Driver / Montaje Con Driver
The driver is actually a small plate with which we can select the color we want for our sign by means of a remote control, it can be bought loose with which we can take advantage of the RGB capacity of the LEDs in different signs. However, if you want to mount them in a fixed color, go to the next section, where we will see how to connect the led strip without driver.
To enhance the assembly with the driver, we will have to solder some small cables to the output of the driver, with the intention of being able to glue a longer piece of the led strip on it, we will glue it with hot silicone in the hole designated for it in the base, leaving the optical sensor to protrude. This is done to make the most of the surface area and add as many leds as possible, however it is not necessary either, since with a few leds, the light will travel throughout the sign with very good results.
Next we will cut and glue the led strip along the base of the sign and solder the wires onto the pads.
Then, we will proceed to pour some hot silicone on the edges of the sign base and place the other piece (sign support) on it.
Fit the metraquilato, connect the Usb and enjoy.
El dirver en realidad, es una pequeña placa con la que podemos seleccionar el color que queremos para nuestro rotulo mediante un mando a distancia, se puede comprar sueltos con lo que se puede aprovechar la capacidad RGB de los leds en diferentes rotulos. No obstante, si quiere montarlos en un color fijo, pase al apartado siguiente, donde veremos como conectar la tira de led sin driver.
Para realzar el montaje con el driver, tendremos que soldar unos pequeños cables a la salida del driver, con la intención de poder pegar sobre este un trozo mas largo de la tira led, lo pegaremos con silicona caliente en el hueco destinado para ello en la base, dejando que sobresalga el sensor óptico. Esto se hace para aprovechar el máximo de superficie y añadir todos los leds posibles, no obstante tampoco es necesario, ya que con unos pocos de led, la luz viajara por todo el rotulo con muy buenos resultados.
A continuación, cortaremos y pegaremos la tira de led a lo largo de la base del rotulo y soldaremos los cables en los pads.
Luego, procederemos a echar algo de silicona caliente en los bordes de la base del rotulo y colocaremos la otra pieza (soporte rotulo) sobre ella.
Encajar el metraquilato, conectar el Usb y a disfrutar.
Step 4: Assembly Without Driver / Montaje Sin Driver
To connect it without a driver and therefore, in a single color, we must print the part called without a driver and hot glue it on the base, leaving the hole for the cable exit in its corresponding place.
Next, we will solder the pads to a usb cable, knowing that for simple colors, we will solder the red cable to +5v and the black cable (ground, GND,-) from the usb to one of the pads named R(red) G (green) or B(blue). If we want more complex colors, the GND must be soldered to several pads of the led strip. As we unite them we will get these colors:
- Red (Red Usb cable soldered to +5v and black cable soldered to R)
- Green (Red Usb cable soldered to +5v and black cable soldered to G)
- Blue (Red Usb cable soldered to +5v and black cable soldered to B)
- Purple (Red Usb cable soldered to +5v and black cable soldered to R and B)
- Yellow (Red cable from Usb soldered to +5v and black cable soldered to R and G)
- Sky blue (Red Usb cable soldered to +5v and black cable soldered to G and B)
- White (Red cable from Usb soldered to +5v and black cable soldered to R,G,B)
Para conectarlo sin driver y por ende, en un solo color, deberemos de imprimir la pieza llamada sin driver y pegarla con cola caliente sobre la base, dejando el hueco para la salida del cable en su lugar correspondiente.
A continuación, soldaremos a los pads a un cable usb, sabiendo que para colores simples, soldaremos el cable rojo a +5 y el cable negro (ground, GND,-) del usb a uno de los pads nombrados con R(rojo) G (verde) o B(azul). Si queremos colores mas complejos, el G deberemos soldarlo a varios pads de la tira led. Según los unamos podremos conseguiremos estos colores:
- Rojo (Cable rojo de Usb soldado a +5v y cable negro soldado a R)
- Verde (Cable rojo de Usb soldado a +5v y cable negro soldado a R)
- Azul (Cable rojo de Usb soldado a +5v y cable negro soldado a R)
- Morado (Cable rojo de Usb soldado a +5v y cable negro soldado a R y B)
- Amarillo (Cable rojo de Usb soldado a +5v y cable negro soldado a R y G)
- Azul cielo (Cable rojo de Usb soldado a +5v y cable negro soldado a G y B)
- Blanco (Cable rojo de Usb soldado a +5v y cable negro soldado a R,G,B)
Step 5: Fin
So far this project is quite simple to do, although it is true that sometimes in the explanations, it seems more complex. Relatively recently I started a YouTube channel, where you can see more easily the process of modifying the base, the considerations when recording the methacrylate and the assembly, if you find it interesting, you can take a look at the projects that I do in (in Spanish with subtitles) https://www.youtube.com/@TecnicasBasicasdeModelismo
If you have any doubts, questions or suggestions, do not hesitate to write. You can follow me here and on instagram @modelkisdeluxe to see my new projects.
Finally, remember that the translations have been checked, but something can always escape me :P
Hasta aquí este proyecto, es bastante sencillo de hacer, aunque es verdad que a veces en las explicaciones, parece mas complejo. Hace relativamente poco que comencé un canal de YouTube, en el que podrán ver mas sencillamente el proceso de modificación de la base, las consideraciones a la hora de grabar el metraquilato y el montaje, por si le resulta interesante, pueden echar un vistazo a los proyectos que en el hago en (en español con subtítulos) https://www.youtube.com/@TecnicasBasicasdeModelismo
Si teneis alguna duda, pregunta o sugerencia, no dudéis en escribir. Podéis seguirme aquí y en instagram @modelkisdeluxe para ver mis nuevos proyectos.
Por ultimo recordar que las traducciones han sido comprobadas, pero siempre se me puede escapar algo :P
