Introduction: Parasit Studio Bit Breaker Guitar Effect Build
Parasite Studio is a DIY guitar effects website that provides various materials for making your own guitar effects, especially those dealing with digital effects such as bitbreaker or fuzz.
The address Parasite Studio is located at
and Bitbreaker deluxe project
https://www.parasitstudio.se/bitbreakerdlx.html
Parasite Studio adalah DIY gitar efek website yang menyediakan berbagai bahan unutuk membuat sendiri gitar efek, terutama yang berhubungan dengan digital efek seperti bitbreaker ataupun fuzz.
Alamat bit breaker terdapat di
Step 1: Software
The software used is Arduino IDE, where Arduino Uno is used to upgrade to the Board. Using ATtiny 85. To upload hex files, you cannot use the Usb Port directly to the details of how to upload hex to
https: //ecetechprojects.wordpress.com/2011/08/06/a ...
Note:
If you use ATtiny85 IC then this is used
ATtiny Pin 7 to Arduino Pin 13 (SCK)
ATtiny Pin 6 to Arduino Pin 12 (MISO)
ATtiny Pin 5 to Arduino Pin 11 (MOSI)
ATtiny Pin 1 to Arduino Pin10 (RESET)
if using Digispark IC then this is used
Digispark P2 to Arduino Pin 13 (SCK)
Digispark P1 to Arduino Pin 12 (MISO)
Digispark P0 to Arduino Pin 11 (MOSI)
Digispark P5 to Arduino Pin10 (RESET)
ATtiny Pin 8 to Arduino + 5v (Vcc)
ATtiny Pin 4 to Arduino GND (Ground)
File required
AVR DUDE
Arduino Uno Go to File> Examples> ArduinoISP in the Arduino IDE
Hex ATTiny85 bitbreaker
Software yang diperunakan adalah Arduino IDE, dimana Arduino Uno dipergunakan untuk uplopad Ke Board.digisapar ATtiny 85. Untuk upload hex file tidak dapat menggunakan Usb Portnya langsung detail dari cara mengupload hex ke
https://ecetechprojects.wordpress.com/2011/08/06/a...
Note:
Jika menggunakan IC ATtiny85 maka ini yang digunakan
jika menggunakan IC Digispark maka ini yang digunakan
ATtiny Pin 8 to Arduino +5v (Vcc)
File yang diperlukan
AVR DUDE
Arduino Uno Go to File > Examples > ArduinoISP dalam Arduino IDE
Step 2: Hardware
For the core hardware of this effect using ATtiny85, which is used is digispark usb board.
Partlist (BOM)
Perforated PCB
Digispark USB
1/4 watt resistor: 10k, 1M.470k, 47k (x4)
Capacitors: 100nF (x2), 10nF, 1nF, 22uF
Jack 2 pieces
DC Jack
Notes:
ATtiny Pin 7 to Digispark P2 ATtiny Pin 6 to Digispark P1
ATtiny Pin 5 to Digispark P0
ATtiny Pin 3 to Digispark P4
ATtiny Pin 2 to Digispark P3
ATtiny Pin 1 to Digispark P5
Untuk harware inti dari efek ini menggunakan ATtiny85, yang digunakan adalah digispark usb board.
Partlist (BOM)
PCB bolong
Digispark USB
Resistor 1/4 watt :10k,1M.470k,47k(x4)
Kapasitor :100nF (x2),10nF,1nF,22uF
Jack 2 Buah
Jack DC
Notes:
Step 3: Assembly
By punching plastic boxes and attaching aluminum sheils,
Knop made of lego
Dengan membolongi plastik box dan menempelkan sheil aluminium ,
Knop dibuat dari lego
Step 4: Test and Final Product
Video exsample in parasite studio site, akan tetapi pngetesan dapat dili
Step 5: Update
Add 3pdt switch
Video
