Introduction: Paring Knife Fix
I was asked to restore a paring knife. I had been wanting to make a knife for a while now and figured this would be a good introduction. It seems that ever since I got a CNC, all projects look like CNC projects to me. This could have also been done by hand but I wanted to improve my 3D modelling capability and practice toolpath configuration so I went the CNC route.
- Wood for the handle - I chose Maple
- Epoxy - I used West Systems G/flex
- Brass rod for the pins- I ordered on Amazon
- Sandpaper
- Danish Oil
Step 1: Take Pictures of Existing Knife
I used Fusion 360 to create the model. If you take a picture of the object beside a measurement device it is really easy to scale the image in Fusion 360 so that the sketch is exactly to scale.
Step 2: Import Images Into Fusion 360
- Insert image as canvas
- Right click on specific canvas and choose calibrate
- Click two reference points on ruler or caliper and type in actual length
Image will be scaled to exact dimensions
Step 3: Trace Pictures and Create Replica
- Trace the image using the sketch functionality
- Once sketch is complete, extrude to proper dimensions
- Since this knife is two piece, I created one side and then mirrored it to get an exact opposite
Step 4: CAM: Generate Gcode
- Change over to the "Manufacture" interface
- Specify the setup and starting material dimensions
- I used a single bit (1/8") and three operations to cut out these handles
- (T1) Face - My starting material was thicker than needed, so this brought it down to the required thickness
- (T1) 2D pocket- cut out the specific pocket for the knife blade to sit in
- (T1) 2D Contour - cut around the profile of the blade handles
Step 5: Cut Out on CNC
Unfortunately I forgot to take pictures of this...
Step 6: Drill Pin Holes and Epoxy Handle
- Drill out pin holes
- Epoxy the handles together with the brass rod
- Trim brass rod and peen over
Step 7: Finish Handle
- I sanded the knife and then used Danish oil to finish
