Introduction: Parking Pass
Hello, my name is Bhavraj. For my final engineering project, I will be working on developing a parking pass system. This project will involve using key components such as distance sensors to detect vehicles, a 7-segment display to provide visual feedback, and a servomotor to control movements like opening or closing a barrier. My objective is to design an efficient and functional system that can effectively manage parking access.
- Servo motor (1)
- Seven Segment Display (1)
- NPN Transistors (2)
- Capacitor (2)
- 330 ohm Resistors (4)
- 10k ohm Resistors (2)
- Popsicle Stick (1)
- Wires (Multiple)
- Wire Stripper (1)
- Distance Sensor (1)
- Breadboard (1)
- Led's (4)
Step 1: Building the MultiVibrator
1. 330 Ohm Resistors to LEDs:
• Connect 330-ohm resistors from the power rail (positive) to the cathode (positive leg) of both LEDs.
2. Capacitors to Resistors:
• Connect the cathode (positive leg) of both capacitors to 10 kΩ resistors, which should also be connected to the power rail.
3. Capacitors to LEDs:
• Connect the anode (negative leg) of both capacitors to the anode (negative leg) of the LEDs.
4. LEDs to NPN Transistors:
• Connect the anode (negative leg) of the LED to the collector pin of the NPN transistors.
5. Capacitors to NPN Transistors:
• Connect the cathode (positive leg) of the capacitors to the base pin of the NPN transistors.
6. NPN Emitters to Ground:
• Connect the emitter pin of each NPN transistor directly to the ground (negative rail).
Step 2: 7 Segment Display
• Segment A → Pin 11
• Segment B → Pin 12
• Segment C → Pin 7
• Segment D → Pin 8
• Segment E → Pin 4
• Segment F → Pin 10
• Segment G → Pin 9
Step 3: Distance Sensor
• Echo → Pin 5
• Trig → Pin 3
Step 4: Servomotor
Orange pin → Pin 6.
