Introduction: Particle Photon - MPL3115A2 Precision Altimeter Sensor Tutorial
The MPL3115A2 employs a MEMS pressure sensor with an I2C interface to provide accurate Pressure/Altitude and Temperature data. The sensor outputs are digitized by a high resolution 24-bit ADC. Internal processing removes compensation tasks from the host MCU system. It is capable of detecting a change in only 0.05 kPa which equates to a 0.3m change in altitude. Here is its demonstration with Particle photon.
Step 1: What You Need..!!
Step 2: Connections:
Take an I2C shield for particle photon and gently push it over the pins of particle photon.
Then connect the one end of I2C cable to MPL3115A2 sensor and the other end to the I2C shield.
Connections are shown in the picture above.
Step 3: Code:
The particle code for MPL3115A2 can be downloaded from our Github repository-DCUBE Store.
Here is the link.
We have used two libraries for particle code, which are application.h and spark_wiring_i2c.h. Spark_wiring_i2c library is required to facilitate the I2C communication with the sensor.
You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// MPL3115A2
// This code is designed to work with the MPL3115A2_I2CS I2C Mini Module
#include
#include
// MPL3115A2 I2C address is 0x60(96)
#define Addr 0x60
float cTemp = 0.0, fTemp = 0.0, pressure = 0.0, altitude = 0.0;
int temp = 0, tHeight = 0;long pres = 0;
void setup()
// Set variable
Particle.variable("i2cdevice", "MPL3115A2");
Particle.variable("cTemp", cTemp);
Particle.variable("pressure", pressure);
Particle.variable("altitude", altitude);
// Initialise I2C communication
Wire.begin();
// Initialise Serial Communication, set baud rate = 9600
Serial.begin(9600);
// Start I2C transmission
Wire.beginTransmission(Addr);
// Select control register
Wire.write(0x26);
// Active mode, OSR = 128, altimeter mode
Wire.write(0xB9);
// Stop I2C transmission
Wire.endTransmission();
// Select data configuration register
Wire.write(0x13);
// Data ready event enabled for altitude, pressure, temperature
Wire.write(0x07);
delay(300);
void loop()
unsigned int data[6];
Wire.write(0x26);
Wire.write(0xB9);
delay(1000);
// Select data register
Wire.write(0x00);
// Request 6 bytes of data
Wire.requestFrom(Addr, 6);
// Read 6 bytes of data from address 0x00(00)
// status, tHeight msb1, tHeight msb, tHeight lsb, temp msb, temp lsb
if(Wire.available() == 6)
data[0] = Wire.read();
data[1] = Wire.read();
data[2] = Wire.read();
data[3] = Wire.read();
data[4] = Wire.read();
data[5] = Wire.read();
// Convert the data to 20-bits
tHeight = ((((long)data[1] * (long)65536) + (data[2] * 256) + (data[3] & 0xF0)) / 16);
temp = ((data[4] * 256) + (data[5] & 0xF0)) / 16;
altitude = tHeight / 16.0;
cTemp = (temp / 16.0);
fTemp = cTemp * 1.8 + 32;
Wire.write(0x26);
// Active mode, OSR = 128, barometer mode
Wire.write(0x39);
Wire.write(0x00);
delay(1000);
// Request 4 bytes of data
Wire.requestFrom(Addr, 4);
// Read 4 bytes of data
// status, pres msb1, pres msb, pres lsb
if(Wire.available() == 4)
pres = (((long)data[1] * (long)65536) + (data[2] * 256) + (data[3] & 0xF0)) / 16;
pressure = (pres / 4.0) / 1000.0;
// Output data to dashboard
Particle.publish("Altitude :", String(altitude));
Particle.publish("Pressure :", String(pressure));
Particle.publish("Temperature in Celsius :", String(cTemp));
Particle.publish("Temperature in Fahrenheit :", String(fTemp));
delay(1000);
Step 4: Applications:
Various applications of MPL3115A2 includes High Accuracy Altimetry, Smartphones/Tablets, Personal Electronics Altimetry etc. It can also be incorporated in GPS Dead Reckoning, GPS Enhancement for Emergency Services, Map Assist, Navigation as well as Weather Station Equipment.
