Introduction: Patio Lounge Table
Patio lounge table is an outdoor accent made from thrift store furniture, vintage wallpaper and spray paint. The vibrant design stimulates conversation and always stays in bloom. The low height makes it a great kids table. You will need; (4) swiveling casters, (4) 1/4-20 x 1 1/2" screws, (4) 1/4-20 threaded furniture inserts, umbrella and umbrella base are optional, wallpaper paste + primer, water-based polyurethane clear.
Step 1: Find + Modify Furniture
Find a used coffee table, remove the top and add swiveling casters.
Step 2: Add Table Top
Find a 48" diameter dining room table. Remove the legs and position the top over the base. Measure and drill four pilot holes where the top will be screwed into the base legs. Drill a hole in the center of the table top for an umbrella (optional). After drilling the pilot holes, remove the top and drill 5/16" diameter "thru holes" and countersink for 1/4-20 screws.
Step 3: Add Threaded Inserts
Drill-out pilot holes in base legs to accommodate a 1/4-20, threaded furniture insert. Four (4) required.
Step 4: Threaded Insert Detail
Detail photo of the threaded furniture insert.
Step 5: Spray Paint + Prep Top
Spray paint the top, sides and bottom of the top with black spray paint. This should be considered a decorative step intended to seal the wood from moisture. Apply a coat of latex primer or wallpaper primer to the top surface only.
Step 6: Cut Wallpaper
Find some vintage wallpaper, consider a pattern of multiple papers and draw cut-lines on the table top as a positioning guide. Cut all wallpaper appliques to finish size, but allow the ends to hang over the outside edge.
Step 7: Apply Wallpaper
Using a foam roller, pour paste to back of wallpaper and roll-out smooth. Lay on top, position and with a plastic squeegee, smooth-out and squeeze out excess glue. Clean excess glue with wet sponge or rag as you go.
Step 8: Apply More Wallpaper
Step 9: Trim Wallpaper
After all the wallpaper is applied, trim the outside edge with a razor blade.
Step 10: Top Clear Coat
With masking tape, create a "fence" or "dam" along all the outside edges. Liberally pour-in clear, water-based polyurethane to provide a durable, thick, weatherproof top coat. For a more aggressive method, surfboard resin could be used as a substitute.
Step 11: Add Flair to Top
Mask top and spray paint a gold edge or complimentary, accent color of the wallpaper, to the edge of the table top.
Step 12: Spray Paint Base
Spray paint the table base black. Don't get overly technical here because much of the base is covered by the top. Shown here is a custom umbrella support post to make the umbrella taller than normal. This support post is an option and is not necessary for umbrella function.
Step 13: Spray Paint Base Bottom
Be sure to paint the base bottom to ensure good water-proofing. Photo shows umbrella post bolted to base. If you are using an umbrella without this custom element simply use a hole in the table top and ""plug" screwed to bottom to secure the umbrella in position.
Step 14: Add Flair to Post
Add a little spray paint "fade" to make the post blend with the table and become part of the top design.
Step 15: Assemble
Screw top to base with 1/-20 x 1 1/2 Flat Head machine screws. Drop in the umbrella. Unfortunately the old umbrella looks bad so, spray paint the umbrella post to match the table.
Step 16: Spray Paint Umbrella Pole
Spray paint the umbrella pole to better match the table design. This looks much better.
Step 17: Enjoy
Start up the BBQ and enjoy. The table base here makes for a nice foot rest. The swiveling casters make it easy to reposition depending on the sun/time of day as well as the type of event.
2nd Annual Krylon Summer Contest
3 Comments
7 years ago on Introduction
This is a great post. Such a cute table! I just wanted to comment and mention that Brookstone sells furniture covers (http://www.brookstone.com/weather-wrap-outdoor-furniture-covers) for all types of outdoor furniture. Right now, everything is 25% off without a coupon code, but you can get it for even less if you visit the Brookstone promo code page (found at http://www.brookstone.com/brookstone-coupons) and use one of the additional coupon codes at checkout! I just purchased some covers for my patio umbrella, and round table and chairs. This way my furniture will last longer despite the rain, sleet, snow, etc. Just thought I'd share!
10 years ago on Introduction
Well written how-to. Easy to understand, and I'm thinking I'll come back to this to use it! Thanks.
Great work! Very creative and well documented.
