Introduction: Pc Shut-Off Trap
Imagine you Are Just Working On Your Computer And When You Click On Your Internet Browser To Roam The Web.
Then Suddenly All Your Folders, Programs, And Applications Start Closing And The Computer Shut Off.
You Sir Have Been Pranked, Enjoy
(An Easy Pc Shutdown Trap You Can Set As And Icon Of The Most Used Icon(s))
*Please Use This Trap Prank In Care. Don't Use On Valuble or Important Computer(s) Or Files*
Step 1: Making the Short Cut
The First This you Do Is Right Click Your/Their Desktop.
Scroll Down To New Then To Shortcut And Click.
You Should Have a Window Named "Create Shortcut" Open
Step 2: Entering the Code
Type In The Box "Shutdown -5 -T -0"
Shutdown -5 Is the code to locate the Windows shutdown sequence.
The -T is time and the -0 Means 0 Seconds to wait before Activating The Process.
*Hint* You Can Set It To Go Off At Any Time
Then Click Next-
Then Finish, Don't Worry You Can Change The Name Later
Then Click Next-
Step 3: Starting the Disguise
Then Click On The Shortcut That Is located On Your Desktop-
Scroll Down and Click On Properties
Then Click On Change Icon
Step 4: Making the Disguise
In The Window That Pops Up-
Click on The New Icon You Want To Set The Trap As, Then Click On ok
On The Properties Window Click On General Located on The Top Right Area-
Rename The Trap To The Desired Diguise
*Warning*
2 Files With The Same Name Cannot Exist On The Desktop-
So Get The Original Program's Shortcut and move it to another folder ot delete it @_@
Then After Naming your Trap Click Apply Then ok-
Put The Trap In The Place Of The Original File And Walk Away :3
*Warning*
Step 5: Making a Custom Icon
If You Want To make Your Own icon Or If You Cant Find The Original
Icon Of The File U Want To Set The Trap As.
Its Easy @_@
On Your Keyboard Tap "Print Screen"
Then open Window's Paint-
Then Go To Edit Then paste
Cut Out The Icon From The Picture And Paste in a New Window
Then Using The Brush Set the color to white and erase all unnesasary excess.
Then Make The Size x32 by x32 And Save As .ico
Then To Get It Just Click On Browse On the Icon Chooseing Windown and locate your icon.
Its Easy @_@
