Introduction: Homemade Peach Mango Shake
This is an easy recipe that doesn't require a blender! What makes it even easier is that it only needs 2 ingredients, so no hassle should be involved.
What you will need:
- Medium sized bowl OR cup about 4 in. in diameter and 5 in. deep
- Spoon
- A sweet tooth!
Ingredients:
- Vanilla ice cream
- Peach mango juice
Step 1: Ice Cream
The first step in making your homemade shake is taking care of the ice cream. For this recipe, you will need to scoop about 3/4 cup of ice cream into your bowl or cup.
Step 2: Juice
The second step is pouring in juice. Whether you want thick or smooth is up to you.
If you want to follow my suggestion, I added about 3 oz.(or 1/4 cup if you desire thicker) of the peach mango juice into the cup or bowl with ice cream..
Step 3: Mix It Up!
The timing for this step varies...
Get the spoon mentioned in the list of things required. Then start mixing the juice and ice cream until it is a smooth mixture. Mix for about 1-2.5 minutes - depending on how much juice is poured in. If you poured in more juice, it shouldn't take as long, and your shake should be slightly liquidy, if you want it that way. If you poured in a little less juice, then the mixture will be thicker.\
After mixing, you're done! Enjoy your homemade, non-blender shake.
