Introduction: Pearl Weaving on Necklace
If you like to weave this necklace is for you! It adapts to any outfit, it is discreet but very nice!
To make this necklace you will need the following material:
-a golden chain (mine is steel)
- a box of small white pearls
-a box of small golden pearls
- transparent non-elastic thread
-a pair of scissors
Step 1:
Using scissors, cut about 1 meter of wire. On this one thread 9 pearls; 1 golden pearl at each end and therefore 7 white pearls between the golden pearls.
Step 2:
Pass the right end of the thread through the second bead starting from the right; the beads will be positioned one after the other. Do the same with all the beads one by one. they will all be positioned in line.
Step 3:
You therefore have all your beads which are linked together and with the right end of the zigzag wire in each bead so that the beads all hold together and do not move.
Step 4:
On one of the threads (any one, it does not distort the creation) thread a golden pearl then a white pearl. Pass the thread through the thread that connects the second and third bead. in order to tighten everything, iron the thread in the white pearl, the golden one and again the white one. The son must come out of the white one at the top
Step 5:
Do the same with all the beads, but this time iron the thread only once, you can't go wrong because there is only One bead anyway. Do the same with all the beads, putting one less on each row. at the end of each line do not forget to put a golden bead.
Step 6:
Repeat step 4 and 5 to weave each row until there are only 2 beads left, so this will be the last row on the 1st side of the creation of this weave.
Step 7:
Do the same from step 4 to weave and finish the second side of this weave.
Step 8:
Thread a small ring on one of the threads to tighten it and make very small knots to hold the thread.
Step 9:
Put your weaving on your chain and it is ready to be worn!
