Introduction: Pedal-Powered Smartphone Charger
We designed a pedal-powered phone charger from old bike parts and drill components. This makes it possible for simultaneous exercise and charging of a cellular device. This invention combines the maintenance of physical and energy-related well-being, conserving a building's electricity output while providing a cardio workout.
List of Materials
  • 1 18-volt cordless drill
  • 7 pipe clamps
  • 1 old bike frame (including bike pedal assembly and bike freewheel)
  • 1 2x2 wooden board
  • 1 2x4 wooden plank (cut into three smaller pieces)
  • ~25 Nails
  • 2 U-clamps
  • 1 USB adapter
List of Tools
  • Solder
  • Soldering Iron
  • Circle saw
  • Bike chain breaker
  • Hacksaw
  • Wire cutter
  • Screwdriver
  • Spanner
  • Cordless Drill
Step 1: Remove Casing
Use a screwdriver to unscrew the screws that connect the drill’s external plastic casing. Once these screws are removed, extract the drill from its casing. Keep the screws for later use.
Step 2: Remove Gears
By hand, remove the top three layers of drill gears, careful to keep meshing gears organized and separate for reassembly.
Step 3: Remove Clutch
Remove the drill clutch (the piece shown in the image above.
Step 4: Reassemble
Once the drill clutch is removed, reassemble the gears in their respective positions prior to disassembling them.
Step 5: Reinstate Drill Bit
Re-twist the drill bit on top of the drill
Step 6: Solder
Using the soldering iron and solder, solder the drill’s wires on the positive and negative terminals on the back of the drill.
Step 7: Re-implement Casing
Once the solder has solidified, take the screws from step 1 and use the screwdriver to re-screw the plastic casing to the drill.
Step 8: Test the Modified Drill
To test that the reassembly has been successful, spin the drill bit and ensure that there is no internal resistance.
Step 9: Remove Wheels From Bikeframe
Begin by popping the wheels off of the bike frame, if they are not already removed. This will leave you with a frame similar to the one shown above.
Step 10: Remove Wire and Chain
Using wire cutter and bike chain breaker, remove the wire and bike chain from the bike frame. This allows for the bike frame to be cut easier.
Step 11: Remove Gears
Using a screwdriver, remove the gears near the back wheel of the bike. Save these plated gears for later use.
Step 12: Cut Bike Frame
Use the hacksaw to cut at the bike frame in the places shown in Figure 2.
Step 13: Remove Pedalcaps
Use a screwdriver to remove pedal caps (if applicable). The removal of pedal caps allows for more universal use of the bike since not all shoes will fit into the pedal caps.
Step 14: Secure Bike Frame to Base
Using 4 pipe clamps secure the bike frame down with the pedals up (See Figure 3).
Step 15: Cut 2x4
Using the circle saw, cut the 2x4 plank into three equal pieces.
Step 16: Attach Drill to Plank
Using 3 pipe clamps attach the modified drill to a 2x4 plank.
Step 17: Attach Plank to Frame
Use 2 U-clamps and attach a 2x4 plank to the front of the bike frame (See Figure 4). The U-clamps need to be secured with a drill.
Step 18: Attach Two Planks to Eachother
Then, attach the 2x4 wooden plank attached to the drill to the 2x4 plank attached to the bike frame. Make sure the gears on the drill and the bike are aligned.
Step 19: Increased Stability, Potential 3rd 2x4
You may use another 2x4 plank to stabilize the drill for increased durability; if you choose to reinforce the drill place the third 2x4 plank perpendicular to the other two, and use it to support the drill, placing it beneath the drill to act as a shelf. If you have the resources, use a saw to cut through the wood and fit the drill in the hole — this will ensure the drill is unmovable.
Step 20: Reinstate Bike Chain
Once the drill is secure, drape the bike chain around both sets of gears. Using the bike chain cutter, cut the chain so that it fits around both sets of gears snugly, and close the chain.
Step 21: Attach USB Adapter
Attach a usb adapter to the wires that extend from the drill. The product is ready for use.
