Introduction: Peeling Large Scale Potatoes Within 5minutes Really
Peeling potatoes is tedious but enjoying them is simultaneously delicious
This tutorial helps u to peel 25potatoes in 3-5 minutes
Step 1: Material Needed
U will need a drill machine
A hard bristled cylindrical brush with a thin shaft which shall fill in the drill chuck
Step 2: Getting Prepared
In case the brush has a bend then u will have to cut the bent portion to make it fit in the drill machine
Step 3: Assembly
Fit the drill machine with the edited cylindrical brush and turn on the drill in order to check that whether the brush rotates symmetrically or no
U r all set for peeling the 25potatoes
Step 4: Preparing the Potatoes
Take the potatoes and put them in a bucket of water they should be dense enough that they rumble over each other
And also have a drain near by for easy cleaning of spilt water
Step 5: Starting the Process
Insert the drill brush at the angle as shown in the pic
Before starting ensure that the drill body is away since water will spill out of the bucket
Watch this video
https://m.youtube.com/watch?v=XY6I71-bajo
Watch this video
