Introduction: Peltier Cannon Water Bottle
About: le Libre choix de savoir et de le dire aux outres
For the camping,office,garden.......1,5 L of your preferred drink.......
run with 12 volt battery or solar panel......
easy to build,all pic is better of my english.....have fun !! :)
Step 1: Material
A metal box,tobacco box,12 volt fan, a peltier module,polystyrene.
Step 2: Assembly
i fix the Peltier module in the base of metallic box with her base (aluminium).
i join the radiator and some polystyrene around,between the metallic box and the module,fix with scotch.
After,i roll some sheets around the metallic box for isolated thermic internal/external.
i join a fan pc,not necessary if you use a little solar panel......Necessary if you use 12 volt (28 watt)
Step 3: The Caps
i joined two tobacco box with scotch and her caps in one side.
same procedure for isolate the box with polystyrene....scotch.....
Step 4: Join a Bottle of Water and 12 Volt
Cin Cin...........brrrrrrrrrr.........
20 minutes with a battery 12 volt ,9 ah for charge.....after you pass with a simple solar panel 12 volt (like photo)
to maintain the agreeable temperature...fresh temperature......
a potentiometer,maybe,is a solution to economy the battery energy if you stay all the time on battery........
Thank's for watch......
shure,if you have questions,post here........bye from Paris......
Step 5:
