Introduction: Pen, Eraser and Scissor Organisor
In this instructable we will teach you how to make a simple pen holder with the help of tinkercad.
the items needed are:
3D-printer
Tinkercad
Step 1:
We are going to start with placing a cilinder
make the cylinder 70 by 70 and 90 high ( the measurements in tinkercad are in Millimeter)
Step 2:
make a cylinder with stripes on it and is see through, and make it 60 by 60 and 90 high
Step 3:
place the see through cylinder in de regular cylinder 5mm from the bottom upwards with on each side 5mm space on each side
Step 4:
group the 2 cylinders and copy it 30 mm next to the original cylinder
Step 5:
make a platform 85 by 50 mm and 5 mm high with the cube
Step 6:
place it in between the 2 cylinders with 10 mm leftover space on each side
Step 7:
Use the grouping button again, and you can choose a different colour as well
Step 8:
use a cube to make a small plate that is 34 mm by 6 mm and 36 mm high
place it 45 mm up
Step 9:
make a small see through plate that is 6 mm by 25 mm and 20 mm in height and copy it
use the see through and make them 52 above the bottom
Step 10:
Put the 2 see through cubes next to each other with 6 in between them
group the 2 see through cubes and the solid one together
Step 11:
place the newly grouped object in between the two cylinders and group again
Step 12:
make a plate that is 67 by 5 mm and 20 mm in height, then copy it
Step 13:
place the 2 plate on either side of the bottom plate colliding with the cylinders
Step 14:
Then group again
Your almost done!
Step 15:
Now you only need to print it on a 3d printer, but because every printer works different we’re not gonna show you that in this instructable
We hope that you enjoyed this instructable and put it to good use just like us
