Introduction: Pencil Stand-holder From a Sewing Bobbin
So here we would make a transformation of wooden sewing bobbins into a pencil holder/stand.
What would you need to make it:
Wooden sewing bobbin
Rust-Oleum metallic finish (gold and silver)
Krylon lacquer or comparable
Walnut oil
InstaMorph 1/2 tsp (moldable plastic)
Small metal dish
Paper towel, latex gloves (for applying finish)
1 chopstick or something similar
Sandpaper 400 grit
Regular home drill or ideally variable speed drill
1 bolt 1/4"x 20 x 4" (thickness of the bolt x threads per inch x length)
2 washers that will fit 1/4" on the 1/4" bolt
1 nut 1/4"x 20 to fit on a bolt
1 drill bit 11/32" ( this size makes a hole with an ideal width to hold a pencil)
Blue tape (or any non-clear)
If after reading instructions you would decide that unwinding/rewinding the thread from a bobbin and sanding your bobbins with a sandpaper is not for you (or you do not have any of these items) you can still do the project by hand. If so then you would not need anything from the list above starting from drill and down (a drill, a screw, a washer, a nut and a tape).
For those people who have a drill at home the drill bit is a very common size and you can find it in a set of drills that come with a drill. As for a nut, 2 washers and a bolt, they can be bought at any hardware store.
I used 3 differently looking bobbins for this project to show different finish
Step 1: Removing Thread From a Bobbin
- clean your bobbin (tags and glue) by taking off labels.
- prepare the drill to unwind the thread from it to another bobbin (at the end you will put the same color thread back on the bobbin)
1. Take the screw, add one washer, push a screw with a washer through bobbin's hole, then add another washer and on top of it screw tightly the nut (look at the pictures). Insert the screw into still, tighten it in the drill. So, know we are ready to unwind the thread from a bobbin.
2. Take off already empty bobbin from the screw. Take a small piece of sandpaper. Rub it slightly against bobbin's surface to remove any discoloration and freshen it's surface. Sewing thread bobbins are pretty much polished, so you just need a slight touch to freshen it up, preparing for the first color coating.
Step 2: Making a Hole to Fit a Pencil
1. To avoid the pencil's graphite tip from being broken when bottoming out we will drill a hole 2/3 of the height of the bobbin. This way it will keep the pencil from touching the bottom of the bobbin. For this, measure the depth you will drill and put blue tape as a marker on a drill bit.
2. Insert a drill bit into the drill, tighten it and start drilling the hole. Please take a look at the video for clarity. Do not drill into the surface of your table! :)
Step 3: Creating a Plug to Close the Bottom Hole in the Bobbin
This is the first time I have used InstaMorph myself. It is a moldable plastic. Packaging has very easy to follow instructions on how to use it. It is on the one of the pictures. For all 3 bobbins I used less than 1/2 teaspoon of this plastic. After placing 1/2 tsp into metal container, and pouring hot water over it, plastic drops become clear in color and very soft. I took a small amount and roll it into a small ball, the size that will fit into the hole. Then push it into the bottom hole of the bobbin. The great thing about InstaMorph plastic is that it can be reheated and re-molded if something went wrong before it really solidifies and glues itself to the surface. So, you have time for mistakes here. Insert a small plastic ball completely into the bobbin's hole. Then place the bobbin's bottom on a flat surface and insert a chopstick into the top hole and flatten the surface of the plastic ball from inside - you created a plug
Step 4: Applying a Finishing Color
1. Spray a bobbin with your choice of the paint and let it dry. I applied two thin coats of paint. It seemed that spraying with just one thin coat was not enough. After spraying let it dry completely.
2. For walnut oil covered bobbin, apply, robbing a good amount of walnut oil into the surface. Let it soak in and put it aside to dry. When it is completely dried apply a coat of Krylon lacquer.
Step 5: Putting Back Sewing Thread
Step 6: Glueing the Thread's End
Step 7: Bobbin Pencil Holder
I entered this instructibles into Homemade gifts contest. Hope you like it.
Thank you
