Pepakura - Convert PDO to PDF
Intro: Pepakura - Convert PDO to PDF
This tutorial will show you how to create PDF files out of your PDO using Pepakura Viewer !
You should now What-is-Pepakura-and-how-to-start andHow-to-use-Pepakura-Viewer
Lots of people were asking me about this tutorial separately.
It seems to be an issue that they cannot solve so easily.
Hope this helps you.
Updated: 2013/01/11 ... 2 hours of work so far :)
STEP 1: Video on Youtube (HD 720p)
In case you prefer video to reading. I made this tutorial on my channel as well:
STEP 2: Get a File to Work With !
Pepakura offers some basic shapes which you can download and try out:
http://www.tamasoft.co.jp/pepakura-en/download/polygons/index.html
OR
Go to Download Page and see section "Download Geometric Models (Free)".
Scroll down where you can get shapes like CUBE:
Download [cube.pdo] (4 kB)
OR
STEP 3: How to Do It !
So you have this program with .PDO files on your drive and you want to print.
What now ?
A.] You can print it at home if you have printer, directly from Pepakura software.
B.] In case you do not have printer = you need .PDF to print it elsewhere.
Here you will learn how to convert .PDO to .PDF file !
1.] Install Adobe Reader to be able to open PDF files.
2.] Go to: http://www.cutepdf.com/products/cutepdf/writer.asp
There you can download CutePDF and GPL Ghostscript both which you need to convert files.
CutePDF will be added into your printer settings and Ghostscript does some magic allowing it :)
HOW TO CONVERT
1.] When you want to convert .PDO to .PDF all you need to do is PRINT as you usually would.
2.] Select CutePDF, print it = the proccess is fake so no printer needed !
3.] It asks you where to save .PDF converted file and that is all ladies and gentlemen ;)
Look at screenshots in this step !
What now ?
HOW TO CONVERT
STEP 4: What Next ?
All my PEPAKURA tutorials in GUIDE:
0.] https://www.instructables.com/id/Pepakura-1/
BASIC:
1.] What is Pepakura and how to start
2.] How to use Pepakura Viewer
3.] Your first Pepakura project
ADVANCED:
4.] How to use Pepakura Designer
5.] Pepakura Convert PDO to PDF
YouTube channel:
http://www.youtube.com/user/krysak4ever
Comment, follow, favourite, send me PM !
BASIC:
ADVANCED:
YouTube channel:
22 Comments
unkerjay 8 years ago
The latest version of Pepakura Designer has a "Print to PDF" option.
krsiak 8 years ago
Hi, thanks.
I will update the tutorial and still this may stay valid for those using older version.
jasonarredondo4808 4 years ago
AshleyV41 5 years ago
hi so i followed allt he needed steps and nothing is happening
i do not know what i am doing wrong
thx ashley
SpiderW1 7 years ago
Hey,
If I were to send a .pdo file to someone could they perhaps send me the PDF in return? I'm on a mac so can't use Pepakura on it. Winebottler doesn't seem to work.
Thanks
3 Great Ideas 7 years ago
I got really angry. Sorry. Why we dowload Cutepdf?? I wasted my time. Just download Pepakura Designer, open pdo file and 'print to pdf', it is ready. Thanks
JDillen 8 years ago
Hello,
How do I add the automatic numbers to the pdf file?
Thanks a lot!
Greetings.
TonyS18 8 years ago
you can use NITROPDF as well
KitG2 8 years ago
Hi,
I converted pdo to pdf, but when I open the pdf its just blank page. Help please! Thanks!
Kekkei_Genkai 8 years ago
I had the same issue. Found a post somewhere else that said to open the print settings from the settings tab and change the option from 'Print lines smoothly (bitmap print)' to 'Print lines clearly (vector print)'. After I made that change I was at least able to see the lines on the pdf. Now I am having an issue getting the texture to show up in the pdf. I am still working on that problem.
krsiak 8 years ago
Hi,
really hard to help this way, and I do net recall this would happen to me.
Sry.
RizzScum 8 years ago
im having the same issues. ive tryed a couple of converts and nothings happening. every once in awhile i get page numbers at the bottom.
qnav.alex 9 years ago
krsiak 9 years ago
that is weird, not sure if happened to me such scenario.
krsiak 9 years ago
Hi,
add me on skype: krsiak.daniel ... write there PEPAKURA NEED HELP, .. so I know, will add you, you can share your screen then and I will be able to help, I cannot really "debug" the issue via comment here ;)
krsiak 9 years ago
Hi,
from what you write that just does not make sense :) Once you see them, if they are "printed" in PDF, all should be ok. Feel free to add me on skype: krsiak.daniel
shawn96 10 years ago
