Perfect Sawhorses: Adjustable and Knock-down Design
Intro: Perfect Sawhorses: Adjustable and Knock-down Design
* Adjustable
* Strong/Sturdy
* Don't require a lot of space to store (ie. knock-down)
* Economical (approximately $15 per sawhorse)
* You would enjoy, or at least have some ability in, assembling pieces of wood
If you have some or all of the above criteria for a set of sawhorses then these will be perfect for you.
Noteworthy:
* The design was inspired by this plan:
http://www.familyhandyman.com/DIY-Projects/Indoor-Projects/Workshop/DIY-Tips-For-Your-Shop/workshop-organization-tips/Step-By-Step#step1
* The finished weight of the saw horse is about 20 pounds.
* Strong/Sturdy
Noteworthy:
STEP 1: Tools Required
Required:
* Drill
* Drill bits (1/2", 1/4", and smaller)
* Wrenches or Socket set
* Skill saw and/or Miter saw
* Pencil
* Level
* Various clamps
Suggested:
* Sandpaper (80 or 120 grit)
* Protractor
* Vise
* Drill
* Pencil
* Level
* Various clamps
Suggested:
* Protractor
* Vise
STEP 2: Materials Required
This list is for two saw horses (measurements in inches):
***Wood***
Qty Description
4 2x4 8 foot (96") stud
3 1x4 8 foot (96") furring strip/stud
1 2x2 8 foot (96") furring strip/stud
***Hardware***
Qty Description
8 4 1/2 x 1/4 carriage bolts
8 3 1/2 x 1/4 carriage bolts
16 1/4 x 1 1/4 fender washers
16 1/4 nuts
4 3/64 x 1 9/16 safety pins
1 1/2 wooden dowel
- 1 1/4 wood screws
- 2 wood screws
- 2 1/2 wood screws
Wood glue is optional for some of the joints
***Wood***
Qty Description
***Hardware***
Qty Description
16 1/4 nuts
1 1/2 wooden dowel
- 1 1/4 wood screws
- 2 wood screws
- 2 1/2 wood screws
STEP 3: Cut List
Again, measurements are in inches
[2x4]
Qty Measurement Description
2 30 Top
4 14 1/2 Top Supports
4 20 Leg Sides
8 21 Legs
[1x4]
4 9 Leg Supports
4 30 Top cross pieces
2 27 Bottom cross piece
[2x2]
2 23 Bottom piece of the Top Assembly
[Angled Cuts]
The Legs and Leg Supports will require angled cuts. I decided with 30 and 60 degree cuts, but you could modify to use only 45 degree cuts to keep it as simple as possible.
The Legs have a 30 degree angle where it will rest on the floor and a 60 degree angle where it will rest against the 'Leg Side' (see picture). The 60 degree cut can be done by hand (would take awhile though), with a fancy miter saw that goes to 60 degrees, with a skill or circular saw, or by clamping a jig to a miter saw set to 30 degrees and the board perpendicular to the miter saw fence.
The Leg Supports (1x4) are easier with two 30 degree cuts.
[2x4]
2 30 Top
4 20 Leg Sides
8 21 Legs
[1x4]
4 9 Leg Supports
[2x2]
[Angled Cuts]
STEP 4: Assembly (1 of 3): Legs
See pictures for instruction ...
STEP 5: Assembly (2 of 3): Horizontal Supports
Once you get two leg assemblies together you can join them with the Top Cross Pieces. I used clamps to keep everything in place as I drilled holes.
These two Top Cross Pieces aren't enough to keep the entire sawhorse square if someone/thing were to lean on it from the side, so I added a Bottom Cross Piece which I attached with 1 1/4 inch wood screws.
STEP 6: Assembly (3 of 3): Adjustable Top
The Top Assembly:
First, attach the bottom with the supports with 2 1/2 inch wood screws (recommended to pre-drill the holes). I put 2 screws in each side. See the picture for how I used clamps to keep it all in place.
Next, slide those pieces into place and clamp the Top of the 'Top Assembly' to the rest of the saw horse while also clamping the Top Supports so they don't move while drilling holes through the Top.
(See the pictures for more detail)
45 Comments
MarkS79 3 months ago
Love the saw horses and would like to make, but can’t download the plans??? Could someone please look at this???
rodney.thornton.355 8 months ago
villager 7 years ago
jotuna 8 years ago
Nice! Downloaded and on the way to getting materials. It will become clear, but what is the minimum and maximum height of the horse?
loftyduck 8 years ago
jotuna 8 years ago
Kernel770 11 years ago
I was searching for some sort of desk-construction alternatives, and I think these sawhorses would make a really nice and flexible, though sturdy desk combined with a table plate!
Definitely a good idea. The pine dowel i originally used bent so it's since been replaced with oak dowel. Adding metal bits would be good as well or using a harder wood (oak, hickory, etc.) for areas that take extra stress would make it more durable, no question.
MelPhleg 10 years ago
it can't be downloaded. i've tried several times.
the pdf page says to open with a different viewer.
downloading it with right-click save-link-as works, but the properties give it as 0bytes.
trying to open it with a on-puter pdf viewer says the file is plain text.
opening it in a word processor program gives a totally blank page.
what happened to the download-able file?
thanks
lyvwyr70 10 years ago
copy and paste to word
paulbsa 12 years ago
skirmishmonkey 11 years ago
I am thinking about making a second set with lighter (thinner) lumber.
Saying that though, these are great for heavier duty tasks and to use around the workshop. I have even used them as a work platform with planks resting on them. (Probably not recommended for environments where the HSE officers breathe down your necks). One extended easily takes my weight (80kg) - again probably shouldn't recommend trying it at home.
The adjustable height is brilliant. I use the wooden dowels and haven't had any issues with them. If you drill the holes to the size of the dowels for a tight fit and make the dowels stick out a few inches either side then you shouldn't have any issues with them coming out mid task.
pbates123 12 years ago
I had a couple of thoughts. Not having built a set yet it seems it maybe a bit wobbly once it is extended past the lower brace. If you were to route a dado on the inside of the legs say ~1/2in. wide and deep facing toward the slide on both sides, and on the slide near the bottom maybe an inch up drill a 1/2in. hole and insert a short piece of dowel. It would ride in the dado and help stabilize top assembly.
Also adding a couple of heavy duty hinges would allow the legs to fold up for more compact storage - might have to do a little engineering to make sure that add-on is strong enough - just a thought!
Great design I like it!!
skirmishmonkey 12 years ago
I realised what I have known for a while - I needed some saw horses. Looking at the local tool shops (I live in Malta and everything is quite expensive) I realised it would be cheaper to buy the lumber and make some myself.
This design fit all my needs - adjustable height, sturdy and above all, because space is at a premium, they collapse down so don't take up too much space.
They took less than a day to make. I followed the 'ible to the letter - including the 60 / 30 degree cuts on the legs - although they came out ok, I did mess up a few feet of 4 x 2 on the 60degree angles with the mitre saw. - ended up cutting 10 legs and choosing the best 8. Next time I would go with the 45degree cuts.
Other than that, a great design - already put to good use. Here is some pics of my horses. Thanks loftyduck for the design and a clear, easy to follow 'ible.
loftyduck 12 years ago
bobbybrus 12 years ago
rjlewis74 12 years ago
Lavon93 12 years ago
I would like to make a pair of these for my Father-in-law...Who has every tool know to modern man!!! I think he would appreciate these.
Uptonb 12 years ago
Thank you very much for improving on the handyman version and publishing this project. They will help me immensely on my projects. :)
