Introduction: Perfect Toast
In this tutorial you will find out how to make the perfect toast for your perfect breakfast.
-Toast bread
-Butter
-Jam(preferably blue honeysuckle jam)
-Salt
-A toaster
-A knife
-A plate
Step 1: Figure Out Your Toaster Settings
In order to make the perfect toast, you need to find your perfect toaster settings. The best way to do that is to test out different settings. However, if you don't have the time for that, you can just try to guess the desired settings yourself.
Step 2: Putting Bread in a Toaster
This step is self-explanatory. You need to put a loaf of bread in a toaster with your preferred settings.
Step 3: Spread Butter on Your Toast
For this step you need butter, a knife and a plate.
When the toast is ready, quickly remove it from the toaster and put it on a plate. While it's still hot, spread butter on it.
Step 4: Put Jam on Your Toast
The next step is putting jam on your toast. You can choose any jam you want, but the best choice would be blue honeysuckle jam. Unfortunately, I had to use strawberry jam because blue honeysuckle jam is so delicious that it wasn't available for this tutorial.
Step 5: Add Salt
Add a little bit of salt. This will create a contrast between different tastes and make your toast objectively better.
Step 6: Enjoy Your Perfect Toast!
The perfect toast is ready. Enjoy!
