Pergola Arbor Seat
2,999
77
4
Introduction: Pergola Arbor Seat
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
The Lady of the House said that she would like a seat in the orchard to contemplate her navel! And being a good husband, with an unhealthy passion for powertools, I thought " I can do better than that"
Step 1: The Uprights
I had a bunch of 4x4 (100mm x 100mm) poles that I bought eons ago for another project that never got done,
So using a circular saw I cut a recess at the top of 4 of them.
Step 2: The Back
So I assembled 2 of the poles with some trellis using 50mm screws and dug a couple of holes with my post hole tool, I also added a horizontal upper from 40 x 100 decking to give the whole shebang some rigidity.
I then made sure it was all level and upright and concreted in with Postmix
Step 3: The Seat Back
I then cut a "bird lip" out of the upright for the seat back top runner, I was going to cut a second one lower for the bottom rail, but then thought better as it would weaken the post too much, so as I was very much "winging" this (making it up as I go along), I used the cut out "wedge instead as an infill to get my angle for the seat back.
Once both top and bottom horizontal were in I cut slats to fit for the back and attached with 50mm screws.
Step 4: The Sides
I used 2 pieces of trellis for the sides to get the correct position for the front poles assembly. These were attached using 75mm nails.
It looks a bit cack handed in the first pic as I was doing this on my own ( as the wife has just had back surgery) so improvisation was called for.
Once I had located one side, I could dig the second hole and square everything up.
Again all concreted in with Postmix
Step 5: Seat Base
Then I put in 2 "fore and aft" pieces at each end to attach the seat slats using 75mm nails, then cut the seat base slats to length (1800 mm) and attached using 50mm screws.
Step 6: The "Roof"
I cut 13 1 metre lengths for the roof, cut off the corners and clamped together.
Then cut 2 slots as shown in each to fit (750mm apart)
Step 7: Fitting the Roof
I spaced out the roof slats evenly and nailed in position using 75mm nails
Just need to stain it and plant something to grow over it and I'm done
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    4 Comments
    SophiesFoodieFiles
    SophiesFoodieFiles
    6 years ago
    My grandma had a similar one & this one looks so cool & amazing! Waw!
    buck2217
    buck2217
    Reply 6 years ago
    Thanks
    DIY Hacks and How Tos
    This looks great. Something like this would go perfect in the wooded area behind my house. How deep did you put the posts?
    buck2217
    buck2217
    Reply 6 years ago
    the deeper ones (right side are in about 2 feet, the shallower about a foot, as the slope dictated. I may put some soil around the base to level the area, not sure yet
