Introduction: Pet Memorial
When your beloved pet dies it is so heartbreaking to get over and when you finally do is a picture in a frame really enough? What do you do with the collar, fur you saved, or tags? This instructable is an idea on how to pay homage to your pet in a small, timeless, tasteful way that will make you feel you have done right by your best friend.
Step 1: Possum Bean
My weiner dog Possum Bean is very much alive but I am using his photo here to demonstrate this Instructable as Rodeo Bean's memorial tin was done a long time ago.
Step 2: What You Will Need:
- 030 thick plastic sheets found here
- Photo of your pet
- Maybe some fur
- Collar and tags
- Favorite toy or a biscuit
- Bits of cremated remains (I hope that is not too terrible to say. I had Rodeo Bean cremated and his remains are in an old tobacco tin now, I used his fur in his memorial-tin but not everyone has their pet's fur)
- Anchovy or Smoked Oyster can
- Tin snips
- Scissors
- Foam mounting squares (optional, you may use a nail)
- Pliers
Step 3: Cans, Tins or Tincans
I used an anchovy tin for Rodeo Bean because it has a little ridge around the tin after you remove the lid. The plastic that keeps everything inside the tin can is able to pressure-fit to snap into the rim.
A smoked oyster tin is another type of tincan to use as there is a little ridge and lip that is left over after removing the top of the can. Little tabs can be cut into the rim to hold the plastic in place.
There must be many cans that have the little lip so go to the grocery store and just look for them in the sardine, anchovy and smoked kipper section.
Step 4: Trace Around Your Tincan Onto the Plastic
Trace around your tincan on the plastic with a pen or sharpie, you are going to trim anyway so the ink marks won't show up.
Step 5: Cut Out the Plastic Frame
This wonderful heavy plastic is fairly easy to cut with good scissors, but you will for sure measure it too large and so there will be lots of trimming to do.
I have taken the protective film off both sides in the rest of the steps but you should wait until you are done as it is as clear as glass and can get just as many finger prints as glass will. Easy enough to clean by rubbing on your shirt though.
Step 6: Lay the Plastic Frame on Your Photo to Trace Around It
Pick a photo large enough so that your pet's head it at the top, you may want to add things to the tin can that your pet owned that will settle on the bottom.
The biscuit I put in Possum's tin stays where it is with a foam mounting square.
Step 7: Notch Some Tabs Into Your Tincan
You will want to fit your plastic with the tabs in the "up" position, you will be able to bend them down with your fingers when you are done.
Step 8: Trim Photo Some More to Fit and Bend Your Tabs Up
Just like with the plastic frame, you will need to trim your pet's photo a few times also to get it to fit. If you trim it too small just use a foam mounting square to keep it in place, otherwise it will just stay where you put it by friction.
Step 9: Put Some Goodies Inside and Trim Plastic (again) to Fit
Step 10: Put a Mounting Tab on the Back
I like the repositionable Scotch foam mounting pads for Possum's can but for Rodeo's I have it hanging on a nail on the wall that is hidden by the collar going around the can.
Step 11: Done
I put Possum Bean's collar and tag from when he was small(er), and half of a biscuit, then I put another collar around the side, it looks more finished that way.
Putting your pet's name on the memorial-tin is your choice, I used one of those label makers, it made it look somewhat retro.
I hope this Instructable helps you in some way with your loss.
