Introduction: Pet Towel Robe
About: I love piggies, crafting, scrap booking, sewing, and cooking. I have degrees in Computer Science and Teaching.
After a warm shower during the NY Winter, the most important thing for your pet is to get dried, and get dried quickly.  Else they get cold from the wet fur and get sick.  And no one wants a sick puppy (or at least no one in my home)  So I decided to use an old towel and make it fit my puppy Snowy better by making him a Towel Robe.  (He only looks miserable because he hates showers and would much rather be smelly and dirty all the time)  I ended up going with a No Sew Approach since my sewing machine is mad at me today.
Materials:
Old Towel
Scissors
Sewing Machine or Hot Glue Gun
Pet Measurements
Ribbon
Step 1: Iron the Towel
If there are any seams from the towel being folded, iron these out.
Step 2: Measure Your Pet
My puppy hates mommy's projects so he rarely sits still for me.  When I measure it is always rough measurements and update as you go.  However, today I got the closest ever and didn't have to make any changes (Yayyy).  To measure the puppy I used ribbon.  The most important thing is to measure around the biggest part of the belly and the length of the animal.  I used the ribbon wrapped it around him and noted the length.  Then I did the same for the length.  (No pictures due to him barely sitting to get the measurement)  I then folded the towel into a rectangle of these measurements and lied it over him to check for adjustments.  I folded it up a little bit to make the length shorter and cut the rectangle twice.
Step 3: Cut the Arm Holes
Take your rectangle and lie it over your pet's back again and mark where the legs are on one side.  Fold the rectangle in half and cut the half circles so it makes two on each side.  Repeat for the second rectangle, then cut the second one in half again.  This gives three pieces, one full and two half shapes.  Lie this over the puppy to check for accuracy before proceeding.
Step 4: To Sew or Not to Sew, That Is the Question.
And in my case, the answer was not to sew.  My sewing machine decided to jam up while attempting to sew the towel so I ended up switching to a No Sew approach and brought out the hot glue gun.  The last picture is what the machine did to my towel :(
The parts that need to be sewn are the three straight parts by the leg holes.  Sew Spots are by the circles.  This sews the top piece (the full piece) to the bottom pieces (the half pieces)  The sew spots are of course either by sewing with needle and thread or in my case by hot gluing.
Step 5: Turn Right Side Up
Turn the pieces right side up.  If you want to add Velcro or a button for the closure you can do so now.  Usually I do when making him clothes, but since this is a robe I decided to make him a belt.  To make the belt I just cut the edge of the towel off so it was a tad wider then his belly length was to give room to tie a small knot with.
Step 6: Get the Puppy Out of the Bath and Put This on Him
Time to take the puppy out of the bath that he hates and put the towel robe on him.  You can see the top, and bottom, and then him wearing it in the living room after he ran away.  Did I mention, he hates baths?
Whether your pet likes the bath or not, this Towel Robe will surely help him to dry faster so he stays warm in the winter.
