Introduction: Phone Holder Charging Stand Dock
This 3D Print figure is a phone holding charging station. The main goal is to hold the phone and charge it underneath, so that it can charge peacefully and you cant watch, play, or have a meeting at the same time.
Phone
Charging wire (Lightning or USB-C)
Fusion 360
PLA Filament
Step 1: Sketching the Phone Holder Frame
  1. Start a New Sketch:
  2. Open Fusion 360 and create a new sketch on the Front Plane.
  3. Create the Phone Holder Rectangle:
  4. Draw a rectangle representing the phone's resting surface.
  5. Use dimensions close to 4.3 in. x 2.5 in. (adjust for your phone's size).
  6. Extrude the rectangle 0.24 in. thick.
  7. Create the Bottom Lip:
  8. Draw a small extruded lip (0.4 in. high, 0.2 in. thick) at the bottom to hold the phone in place.
  9. Fillet the Corners (Optional):
  10. Apply a fillet (0.12-0.20 in.) to smooth out edges for a more polished look.
  11. Add an Overall Slot on the bottom lip (Symmetric extrude cut)
  12. 0.747 in. width x 0.297 in. height; 1.044 in. wide (Charging output hole)
Step 2: Extruding the Holder
  1. Select the Profile: Choose the entire phone holder sketch.
  2. Extrude the Frame: Use the Extrude tool to add depth (~0.4 in.) to the frame.
Step 3: Creating the Support Rod
  1. Create New Sketch on the Bottom Surface: Start a new sketch on the back bottom center of the holder.
  2. Draw a Circle: Draw a small circle (0.25-0.5 in. diameter) at the center to act as a support rod.
  3. Extrude the Rod: Use the Extrude tool to pull the rod downward to the base (3-4 in. length).
Step 4: Creating the Base
  1. Create New Sketch on the Bottom of the Rod:
  2. Start a sketch on the bottom plane of the rod.
  3. Draw the Circular Base:
  4. Draw a large circle (3-5 in. diameter) for stability.
  5. Extrude the Base:
  6. Use the Extrude tool to pull the base up (0.2-0.4 in. thick).
Step 5: Adding Tilt to the Phone Holder
  1. Modify the Rod Angle:
  2. Select the Move/Rotate tool and adjust the phone holder's tilt (20-30° backward) for a comfortable viewing angle.
  3. Join Components:
  4. Ensure the frame, rod, and base are joined as one solid body.
Step 6: Final Touches
  1. Add Fillets to smooth sharp edges.
  2. Use Chamfers to refine transitions.
  3. Apply Materials & Colors for a more realistic look.
Now you have a tilted Phone Charging Dock designed in Fusion 360!
