Introduction: Phone Light
With this project i just want to do a light device for my smartphone.
- Led light strip (white).
- Wood box.
- Soldering wire.
- Connection wires.
- Soldering gun.
- Some nuts and bolts.
- 12 volt power supply cable.
Step 1: Procedure
I take the measures of my cell phone and punch a hole trough the wood box. After this i put some white paint over it.
Step 2: Placing the Lights
Split the light strip, i divide it in segments of 3 each. Take the total distance of the remaining surface and spread the light segments in a uniform way.
Step 3: Place the Power Supply Connection
In this step i punch another hole (with a drill) in the lower right part of the wood to place the holder of the 12 volt connection.
Step 4: Soldering the Lights
Be careful to place the positive an negative poles of the strip to the same polarity, i usually test the light every time i place soldering wire.
Step 5: And That's It...
This is the way it look the device when is finished. After that i just try to set up a bolt and some screws to put the light on a tripod.
