Introduction: Phone Loading Station
This is a quick tutorial on how to make a simple loading station for your phone using only the box of the phone itself, a biro and a cutting knife.
Step 1: Marking
First we are going to mark the spots where the holes for the cable should go.
It's important to make sure your marks are in sync with your phone.
Every phone's dimensions are different so you should see for yourself.
Hint: Use the backside of the cable to mark the spot where the hole should go.
Also useful: if your phone has a big power button, punch a hole for that button aswell.
It makes sure your phone doesn't switch on/off when you put it in the box.
Step 2: Cutting
Next (and final) step is to cut out the marked areas with a cutting knife.
Look out with the knife!
After this you should be ready to go.
