Introduction: Phone Stand
Do you need a place to charge your phone or watch? Do you always loose where you charge it? While I do and that is why I made this Phone stand. I always forget to plug in my phone and watch so it dies on me. I thought if I had a place to put it. I would not loose it as often. So I made this Phone Stand.
In this instructable I'm going to share my design with you.
1. 3D Printer
2. Filament for Printer
3. Phone Charger
4. Watch Charger
5.Fusion 360
6. Computer
Step 1: Sketch One
Create the sketch on the side plane in the shape of the image attached.
Step 2: Extrusion One
Extrude the sketch -7 inches as shown in the image.
Step 3: Sketch 2
Create a sketch on the side of the body that matches the one in the attached image.
Step 4: Extrusion Two
Extrude the sketch -1 inches so it matches the image.
Step 5: Sketch Three
Create a sketch on the same side as the last one. Make sure to match the image.
Step 6: Extrusion Three
Extrude the circle on the side -2 inches so it matches the attached screen shot.
Step 7: Extrusion Four
Extrude the line going down the side of the body -1 inches like shown in the image.
Step 8: Sketch Four
Create a sketch on the bottom face of the body. The sketch is shown in the attached image.
Step 9: Extrusion 5
Extrude the circle and paths -1.5 inches to match the image above.
Step 10: Extrusion Six
Extrude the outside part to attach the two pieces one inch. You can see it shown in the attached image.
Step 11: Sketch Five
create a sketch on the bottom plane. It is a 5 by 5 square with the cut out to attach the parts as seen in the image attached.
Step 12: Extrusion Seven
Extrude the sketch up 2 inches. It can be seen in the attached image.
Step 13: Sketch Six
Create a sketch with a 1 by 2 rectangle in the top left of the second body.
Step 14: Extrusion Eight
You will need to extrude the rectangle down 1 inch in the join command not cut. For help look at the attached image.
Step 15: Sketch Seven
Add a sketch to the top of the second body as shown in the image.
Step 16: Extrusion Nine
Extrude the circle up 3 inches as seen in the image provided.
Step 17: Extrusion Ten
Extrude the inner circle down 2 inches so it goes all the way though.
Step 18: Sketch 8
Create a sketch at the bottom of the bodies that allows the cord to go out as shown in the provided image.
Step 19: Extrusion Eleven
extrude the line up 1.5 inches to allow the cord to exit
Step 20: Sketch Nine
Create a sketch on top of the circle in the shape of a 2 inch square. as shown in the image.
Step 21: Extrusion Twelve
Extrude up 1 inch
Step 22: Sketch Ten
Create a sketch on top of the 2 inch square as shown in the image provided.
Step 23: Extrusion Third-teen
Extrude it down .9 inches as shown in the image.
Step 24: Extrusion Four-teen
Extrude up .1 inches form the bottom circle as shown in the image provided
Step 25: Sketch Eleven
Create a sketch on top of the second body that is a 1 by 5 rectangle for help look at the attached image.
Step 26: Extrusion Fifth -Teen
Extrude the sketch up 3.5 inches as shown in the image above.
Step 27: Sketch Twelve
Create a sketch on the last extrusion that follows the matching one form the first part for help look at the image provided.
Step 28: Extrusion Six-teen
Extrude the part all the way though so that it is no longer their as shown in the attached image.
