Introduction: Phone/Music Player Speakers Plus Charger Base
This is an awesome life hack especially when you can't buy something expensive.
What you need:
iPhone/iPod
Earphones
Toilet Paper Cardboard Inside
Ball point pins
One twisty tie
Tape
What you need:
iPhone/iPod
Earphones
Ball point pins
One twisty tie
Tape
Step 1: Use Up Your Toilet Paper
Obvious isn't it? XD
Step 2: Get Your Toilet Paper
Make markings were the charger port will be.
Step 3: Cut.
Cut along the lines with a knife and double check that the charger port will fit. ONLY THE METAL PART OF THE CHARGER SHOULD SHOW. NOT THE WHITE PLASTIC.
Step 4: Add the Pins
Poke the pins in the bottom of the toilet roll. It should look like the pic shown above.
(Optional; cut the sharp metal point with pliers).
Step 5: Position the Charger
Carefully put the charger in to the spot that was cut.
Step 6: The Sound
With the twisty tie, tie the earphones to look like the pic. Put the earphone roll in the in the toilet paper thing. Connect the earphones to the iPod. Tape the earphone plugs on to each side of the roll depending on if they are left or right. Tape the left plug with the left side of the roll, the right with the right. Easy. Make sure that when you tape it, don't let the plugs too close to the outside. You want it to sound pretty loud.
Step 7: DECORATE!
It doesn't have to look just like a toilet roll. Add designs and decorations! Make it look like a Beats pill! Hope you have fun
