Introduction: Photo to Stamp
In this article I will show you how to convert picture to stamp using Photoshop. You can also make digital stamps online.
Let’s see how to create rubber stamp in Photoshop and how to convert photo to stamp online.
Step 1: Convert Photo to Stamp With Photoshop
To create a stamp effect in Photoshop is not very easy but not very hard either. It can take you about 10 minutes to make a digital stamp.
Step 2: Draw a Circle in Photoshop
Pick the Ellipse Tool. Keep the Shift key pressed while you draw, to create a perfect round circle. Set the color to white.
Step 3: Add Your Photo
Add your photo in a new layer. Right click and choose Create Clipping Mask.
Step 4: Posterize Image in Photoshop
Add a Threshold adjustment layer. Right click and choose Create Clipping Mask.
Alternatively, you can use the Photocopy Filter or the Stamp Filter from Filters gallery to create the stamp effect.
Step 5: Adjust the Image
To adjust the photo contrast, click on the Photo layer and use the Dodge Tool or the Burn Tool to lighten or darken certain areas.
Step 6: Merge Layers in Photoshop
Select all the layers, right click and choose Merge Layers. Name the layer Photo to Stamp.
Step 7: Remove White Background in Photoshop
Open the Layer Style Window > Blending Options > Blend If and Remove white.
To quickly remove the white background, use this free remove white background Photoshop action.
Step 8: Add a Circle Outline
Set the Fill to 0%. Add a Stroke layer style of 7px.
Step 9: Duplicate Layers in Photoshop
Press Control+J to Duplicate the Ellipse Layer. Press Control+T to resize the shape to 110%. Set the Stroke layer style to 5px.
Press Control+J to Duplicate the Ellipse copy Layer. Press Control+T to resize the shape to 130%. Set the Stroke layer style to 12px.
Step 10: Add a Circle Border
You can also add a circle border using these circle shapes for Photoshop.
Step 11: Add Circle Text
Go to the the Ellipse 2 copy layer. Pick the Horizontal type tool and click on the edge of the ellipse to add circle text.
To write text around a circle you can also use this free circle text Photoshop action.
Step 12: Add Grunge Texture
To create a grunge effect, use textures. Add a grunge texture above the stamp smart object. Add a Layer Mask to the stamp smart object. Go to Image > Apply Image. Hide the grunge texture layer to see the result.
The same distressed effect can be obtained with a texture png image. You can basically use any grunge texture as mask for making the stamp effect. This method works great for any type of layer: shapes, text and photos.
Step 13: Stamp Effect in Photoshop
Optional, you can select all the layers and convert into a smart object. Then, it’s easy to change the color and make a red stamp for example.
So, here is the result for the photo to stamp effect made from scratch in Photoshop. In the same way you can create a word stamp by replacing the photo. But, I personally prefer these kind of custom rubber stamps with images for different creative projects.
Step 14: Rubber Stamp Photoshop Action
If you want something simple with quick results, you can try Photoshop actions.
Use this rubber stamp action to create the same result in just a few seconds. The rubber stamp mockup that is included in the pack works just as good.
