Photobooth DIY
Intro: Photobooth DIY
For our wedding, we knew we wanted to have a photobooth, so we did a lot of research into DIY vs renting. Rentals were quite expensive (around $600-$1200) and DIY range from $0 on up depending on how much you already have. On the easy side there was: setup your computer with its web cam and use some photobooth like app. On the hard side there were custom circuitry with fancy triggers and printers etc.
I settled on a middle path. Some digital cameras now have a digital output (usually micro HDMI). When hooked up to a monitor the camera can display pictures that have been taken, or (and more interestingly for this project) it can show whatever the camera is seeing!
The best part of a photobooth is people seeing themselves before the photo and being silly! Since my camera has that output all I needed to do was point the camera one way, have a monitor facing the same way, then throw in a remote and watch the fun that ensued. In order to make everything pretty I had to build a box to hide the technology.
This post is mainly meant as inspiration, so I won't be including too many specific dimensions. We went with a design that could be set on a table
STEP 1: Frame
We went to Home Depot and bought 2 pieces of plywood and found some spare 2×4’s in the attic. Found a flush mount monitor kit on amazon and a spare computer monitor in a closet. I started with the main front face (where the monitor would be attached facing the photo-takers), adding 2x4s for structural support. Then I attached my flush monitor mount to the front of the frame.
I wanted the camera to be above the monitor because pictures from above are supposedly more flattering. I bought a little swivel that I could mount into the wood, so I put another 2×4 at the right height for that. Here is where my previously unmentioned planning came into play. I actually did measure my monitor and camera to make sure everything would fit on the front panel. From there it was a bit of improv as the project went on though. For this build I had the overall shape in my head but determining all the lengths, angles, heights etc ahead of time didn’t seem necessary for something that would most likely be used a few tines. I would add each element off of the previous and measure everything to fit together as I went. Again, this is instructables is mainly meant for inspiration. I hope some of you will be inspired to make your own and I would love to see photos if you do!
I wanted the whole back panel to open on hinges so that the camera would be easily accessible and the whole thing would be easy to assemble and break down. A quick trip to Home Depot and we found these cabinet hinges that worked out well.
For the sides I just pressed a sheet of plywood against it’s current shape. Traced the lines. Measured in by the width of the sheet, then cut! To cut the hole I needed for my camera lens, I used my Milwaukee hole cutting set. A bit on the pricey side but they are AMAZING! Plus I love the case as I’m a have-a-place-for-it-or-loose-it guy.
For a more finished look we used our favorite Minwax dark walnut wood stain. Super easy way to unite all the wood in a piece and make it look a lot more finished. Of course we didn’t get pictures of this though :P But I use an old rag or t-shirt and wipe the stain on and off and it is super fast. I also usually wear rubber gloves too because that stain works on skin too.
Almost all finished, but moving it around was a little troublesome. No grips on the sides. Another Home Depot trip fixed that though with some standard drawer pulls.
STEP 2: Electronics
I went with an older camera (the Samsung galaxy camera) because it has the aforementioned video out (shown in the first image), but it also has a few other neat tricks. It has wi-fi... so during the wedding it was uploading pictures to the internet so that the guests could see and re-share them on whatever social media they liked :)
I also included a picture showing the hole I cut in the middle to feed out the power and video cables to the monitor.
A great thing about this setup was the remote! This made taking pictures so easy we got over 400 at the reception :D We attached it with some pretty bakers twine.
STEP 3: Enjoy!
Hope this tutorial gave you some good ideas!! If you have any questions, I will answer them and update the guide too.
If you want to make that backdrop you see in the final photo, we have an instructable for that!
You can also find us at:
Instagram (sneak peeks @evanandkatelyn)
YouTube (all our DIY videos)
Patreon (if you wanna support us, but no pressure!)
Pinterest (stuff that inspires us)
Blog (includes tutorials from our pre-YouTube days)
Twitter (us, in 140 character doses)
Facebook (be our friend) ………………………………………………………………
Note: This post contains affiliate links. Thank you for supporting us!
