Introduction: Photopea Tutorial Project: Hallucinogenic Plant Poster
This is a tutorial on how I created a poster on different plants that make you hallucinate. The tools I used are: Rectangle Select, Magnetic Lasso, Patch Tool, Eraser, Type Tool, Opacity Adjustments, and Brightness & Contrast Adjustments.
Step 1: Step One: Starting a New Document
First what you need to do is push new project and choose what type of document best fits what you will be doing in you work. I chose A3 from under print and then pushed create.
Step 2: Step Two: Editing Image
I copied an image of some foxglove I found online and then pasted it into the document. I then used the magnetic Lasso tool to get rid of the background and make it so that it was just the flower left.
Step 3: Step Three: Image Opacity
I double clicked on the layer that the flower was in and lowered the images opacity, to make it more faded.
Step 4: Step Four: Creating Words
I clicked the T (to create words) on the side to type "hallucinogenic flowers", and changed the font and size of the words. I then went to where it says warp and edited that to make it more curved.
Step 5: Step Five: Adding Brightness and Contrast
I clicked on the image I wanted to edit and went to Image-Adjustments-Brightness & Contrast, and then changed some of that.
Step 6: Step Six: Group the Layers
Click Layer and then use hold command and G at the same time to group them.
