Introduction: Photoshop Tutorial
Tutorial on how to recreate a Harry Potter poster.
Step 1: Insert and Arrange Images
First you are going to want to find all of the images that you want to use, your going to want to save the image in a google browser and then drag them into the workspace.
Step 2: Quick Selection Tool and Vector Mask
You are going to go to the tool bar and click quick select, then you are going to click the image and using the + and - tools at the top of the tool bar to adjust how much of the image you need to use. After you have to desired amount of image selected you need to go to select and click inverse so that when you click the backspace the background is deleted not the image itself.
Step 3: Background Image and Adjustment of Layers
Next you need to search up a picture of Hogwarts an will do it just need to be the background since Hogwarts was the location of most of this series. You will want to make this the first layer so it is in the background of all the images that instead of covering them up.
Step 4: Background Hue Adjustment
You need to adjust the hue and saturation, to do this you need to click on the desired layer, and then do to this you need to go to Image and click on adjustment then click on Hue and saturation. Then a little editor will pop up and you can play around with the Hue, saturation, and lightness until the desired color arises.
Step 5: Auto Contrast
You are going to want to click on all of the layers except for the background layer and then you need to go to image and click auto contrast, this will make your images pop just a little bit more.
Step 6: Opacity of Images
You are going to adjust the opacity of Voldemort to do this you need to right click on the Voldemort layer and select blending options, then you want to use the opacity bar and bring it down to 58 percent.
