Introduction: Pi Shaped Necklace Using Tinkercad
Using tinkercad I'm going to show you how to make a pi shaped necklace.
1. Tinkercad and some experience using it.
2. 3D printer if you are planning to 3D print it out
Step 1: Making the Legs
Get a square and press the corner and put the length as 35 and width as 5 then press the dot on top and enter 5. Click on the square and press ctrl+d and press the right arrow on your keyboard and that should move the other one to the right.
Step 2: Making the Top
Get another square and press on the corner and put in 6 as length and 38 as width and height 5. Put it in front of the legs then select it then press ctrl+g. If you don't know how to press somewhere on the workplane keep holding and pretend your dragging something and a box appears then do this and make sure it is in the box then press ctrl+g.
Step 3: Making a Hole on Top
Get a grey cylinder and press the dot on the corner and put 5 in the 2 boxes. Put it in the midlle of the top and select it then press ctrl+g.
Step 4: Finished!
Now if you want you can 3D print it out and tie a string in the hole and wear it.
