Introduction: PiPod Shuffle
🎧 PiPod Shuffle
The PiPod Shuffle is a DIY digital music player built using a Raspberry Pi. It automatically plays MP3 files from a local folder in order or shuffle mode, with simple keyboard controls. Designed to mimic the minimalist charm of the iPod Shuffle, it runs headless or with a GUI, and features:
  1. Automatic playback on boot
  2. Shuffle & skip controls via keyboard
  3. Favorite tracks system
  4. Freeze recovery to skip stuck songs
  5. Customizable, compact, and perfect for offline music listening!
-Raspberry Pi, with audio jack. Must be able to run MPG123(ie. 2 or higher)
-Micro SD card or USB(If USB boot is enabled)
-Power source
-Phripherals(Mouse, screen, keyboard, headphones)
-MP3 files
Step 1: Prepare Your Music Folder
  1. On your Pi desktop, open the File Manager.
  2. Navigate to /home/pi (your home folder).
  3. Create a folder called Music if it doesn’t already exist.
  4. Copy your MP3 files into /home/pi/Music/ using drag-and-drop or USB.
Step 2: Install MPG123
Open a Terminal window on your Pi.
Run:
sudo apt update
sudo apt install mpg123
Step 3: Copy the PiPod Python Script
Create a new file play_music.py in your home folder:
  1. Right-click on the desktop or in your home folder and select New Document → Empty File.
  2. Name it play_music.py.
  3. Open it with a text editor (like Mousepad or Leafpad).
  4. Paste your PiPod Shuffle Python code inside and save.
Step 4: Run the PiPod Shuffle Script
  1. Open Terminal.
  2. Run:
python3 /home/pi/play_music.py
  1. You should hear your playlist start playing.
  2. Use keys while focused in terminal to control playback:
  3. n = next track
  4. s = toggle shuffle
  5. f = favorite current song
Step 5: (Optional) Autostart on Boot With GUI
If you want the PiPod Shuffle to start automatically when the Pi boots into desktop:
  1. Click the Raspberry menu → PreferencesAdd/Remove Software → search for “Startup Applications” and open it.
  2. Click Add.
  3. Name: PiPod Shuffle
  4. Command:
python3 /home/pi/play_music.py &
  1. Save and reboot your Pi to test.
Step 6: (optional) Enclosure
Sadly, Pi 3's don't fit into Altoids tins, but you could make one out of cardboard, laser cut wood, or make one with a 3d printer. I used an old green plastic box and modified it with tin snips.
