Introduction: PiZero Colored Weather Station
I want to show you in this project how to build a nice looking weather station based on Raspberry Pi Zero W for wall mount with weather forecast and coloured 2.8 inch TFT screen.
Step 1: Tools & Materials
Materials:
- Raspberry Pi Zero W
- AZ-Touch Pi kit
- SD card (8GB or bigger)
Tools:
- Soldering iron
- solder wire
- long nose plier
- mini side cutter
- multimeter
Step 2: Assembly
This project based on our AZ-Touch Pi0 kit for Pizero. Please follow the attached assembly instruction.
Step 3: Software
The software based on the great work of LoveBootCaptain.To make it compatible to AZ-Touch it was needed to recompile the rpi--display-overlay driver. You will find a copy of the changed driver and prepared Raspbian image here
Step 4: Installation
Download the image and copy it with Win32DiskImager to an SD card. You can follow this tutorial to setting the Wifi headless.
Step 5: Weatherbit.io Account
Go to weatherbit.io and register for a free account to get an API key
Step 6: Edit the Config File
Now establish a SSH connection (via Putty) to the PiZero!
cd
cd WeatherPi_TFT
sudo nano config.json
- replace xxxxxxxxxxxxxxxxxxxxxxxxx in "WEATHERBIT_IO_KEY": "xxxxxxxxxxxxxxxxxxxxxxxxx" with your own API key
- replace de in "WEATHERBIT_COUNTRY": "de" with your country code
- replace en in "WEATHERBIT_LANGUAGE": "en" with your preferred language
- replace 10178 in "WEATHERBIT_POSTALCODE": "10178" with the postal (zip) code of your city (default loaction is Berlin)
- for language-support, please refer to -> Weather.io API Docs
Reboot your Pizero. The weather station will start automaticaly after reboot.
