Introduction: PickleBall Racket Holder Made From Recycled PickleBalls!
PickleBall Paddles need organization! And what better way to build a Pickle Ball Paddle Holder than using broken and damaged pickle balls! 100% recycled materials makes this a great solution for organizing your PickleBall Paddles
PickleBalls or any High Density Polyethylene (HDPE), a WasteFree23 Heat press..see the instructions on how to build a heat press for less $300 USD at wastefree23.org or on instructables. Tefllon, a mold, drill and 2" hole saw. That is it..easy!
Step 1:
place teflon sheets on the bottom of the heat press to keep the HDPE pickle balls from sticking as they are heated to 170c
Step 2:
Place broken pickle balls or any hdpe. At this low temperature the plastic does not "flow" very much so the plastic you place should be spread out.
Step 3:
close the press...it will take 5 to 15 minutes to soften the balls
Step 4:
add balls or parts of balls as needed to fiill most holes. Peal back the teflon sheets to inspect. Careful. it is hot!
Step 5:
Have a male mold ready. We used a 2" abs pipe ontop of a similar width piece of wood to make a U shape. Press tighly and hold for a few minutes as plastic cools
Step 6:
Teflon being removed from the plastic
Step 7:
Drill 2 inch diameter holes spaced 1/2 an inch apart on the top and bottom of the racket holder
