Introduction: Pico OTA
This project shows how to upload Arduino sketches to a Raspberry Pi Pico W (or Pico 2 W) over Wi-Fi (OTA = Over-The-Air).
After one USB upload, you can update your Pico wirelessly from Arduino IDE - no more unplugging USB cables.
You will do:
1. Install the Arduino-Pico core (RP2040)
2. Install the PICO_OTA library
3. Select a Flash Size that includes FS (LittleFS) - this is critical
4. Upload once via USB
5. Upload later via Network Port (OTA)
Hardware
- Raspberry Pi Pico W (or Pico 2 W)
- USB cable (for the first upload)
Software
- Arduino IDE (1.8.x or 2.x)
- Arduino-Pico core (Earle Philhower RP2040)
- PICO_OTA library
Network
- Your Pico W and your computer must be on the same Wi-Fi network (same LAN).
Step 1: Install Arduino-Pico Core
1. Open Arduino IDE
2. Go to File > Preferences
3. Add this URL to Additional Board Manager URLs:
https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
4. Go to Tools > Board > Boards Manager
5. Search for pico and install:
Raspberry Pi Pico/RP2040/2350 by Earle F. Philhower, III
Step 2: Install the PICO_OTA Library
Two ways to install - choose one:
Method A: Arduino IDE Library Manager (if available)
1. Go to Sketch > Include Library > Manage Libraries
2. Search for PICO_OTA
3. Install the library by wedsamuel1230
Method B: Manual Install (always works)
1. Download from:
https://github.com/wedsamuel1230/Pico_OTA
2. Extract the ZIP file
3. Move the Pico_OTA folder to your Arduino libraries folder:
- Windows: Documents\Arduino\libraries\
- Mac: ~/Documents/Arduino/libraries/
- Linux: ~/Arduino/libraries/
4. Restart Arduino IDE
Verify installation:
- Go to File > Examples
- Look for PICO_OTA - you should see example sketches there
Step 3: Select the Correct Board Flash Settings (CRITICAL)
1. Go to Tools > Board
2. Select Raspberry Pi RP2040 Boards > Raspberry Pi Pico W (or Pico 2 W)
CRITICAL: OTA requires filesystem space (LittleFS). You must select a Flash Size option that includes FS.
Recommended example setting:
- Tools > Flash Size > 2MB (Sketch: 1MB, FS: 1MB)
Do NOT choose a "No FS" option, or OTA will fail.
Step 4: Open an Example Sketch
Go to:
File > Examples > PICO_OTA
Recommended for classes / teams:
Pico_OTA_test_with_Dual_Core
Why dual-core? OTA runs on Core 1, while your project logic runs on Core 0. This keeps your application responsive and makes it easier to teach: students can focus on Core 0 only.
Optional: Pico_OTA_test (single-core) is simpler, but OTA shares the same loop and can be impacted by blocking code.
Step 5: Dual-Core Workflow (Hide OTA in Secret.h, Code on Core 0)
In the dual-core example, all OTA-related setup is intentionally placed in secret.h.
Important (recommended for classes): Treat secret.h as a protected / instructor-owned file. Students/users should not modify OTA logic there. They should only write application code on Core 0 in the main .ino file.
What lives in secret.h (Core 1):
- Wi-Fi credentials (ssid/password)
- OTA hostname / OTA password
- setup1() and loop1() that run on Core 1 to keep OTA alive
What students should edit (Core 0):
- setup() and loop() in Pico_OTA_test_with_Dual_Core.ino
- Their sensors, motors, UI, logic, etc.
Dual-core secret.h example (do not change the OTA parts):
const char *ssid = "Your_SSID";
const char *password = "Your_PASSWORD";
const char *hostname = "pico-ota"; // device name shown in Network Ports
const char *otaPassword = "admin"; // change this for real projects
void setup1() {
otaSetup(ssid, password, hostname, otaPassword);
void loop1() {
otaLoop();
Core 0 template (this is where you code):
void setup() {
Serial.begin(115200);
// Your setup code here
void loop() {
// Your application code here (Core 0)
// OTA is handled on Core 1 in secret.h
Why hide OTA in secret.h?
- Prevents accidental edits that break OTA (common in teaching labs)
- Keeps security-sensitive settings (passwords) in one place
- Lets students focus on Core 0 application logic without learning OTA internals first
Security tip: Use a strong OTA password for real projects (avoid "admin").
Step 6: First Upload Via USB (one Time)
1. Plug your Pico W into your computer via USB
2. Select the USB port: Tools > Port > your COM port
3. Click Upload
Open Serial Monitor at 115200 baud and note the IP address.
You should see logs like:
[OTA] Connecting WiFi...
[OTA] WiFi connected, IP: 192.168.1.100
[OTA] LittleFS mounted
[OTA] Ready for OTA updates
Step 7: Upload Wirelessly (OTA)
1. In Arduino IDE, go to Tools > Port
2. Look under Network Ports
3. Select your device (it may show as hostname at IP)
4. Click Upload again - now it uploads over Wi-Fi
Tip: Keep the Pico powered during OTA uploads.
Step 8: Use PICO_OTA in Your Own Sketch
Minimal pattern:
#include <pico_ota.h>
const char *ssid = "YourWiFi";
const char *password = "YourPassword";
void setup() {
otaSetup(ssid, password, "my-device", "my-ota-password");
void loop() {
otaLoop();
// Your code here...
Notes:
- Call otaSetup(...) once in setup().
- Call otaLoop() often in loop() (avoid long blocking delays).
Step 9: Troubleshooting
LittleFS mount failed / No filesystem
- Re-check Tools > Flash Size and select an option with FS.
- Upload once over USB again after changing the Flash Size.
Device not showing in Network Ports
- Confirm the Pico and your PC are on the same Wi-Fi.
- Check Serial Monitor for the IP address.
- Check firewall rules on your computer.
OTA password issues
- Make sure the password in your sketch matches what you type when uploading.
